Rinse it and empty it before you cap the drains and fill it up. This helps get out any bad water which may have been left behind.
Then follow your normal filling stuff: fill and balance, but be sure to give it a good strong dichlor shock - I would say that two ounces should be sufficient - and let that run through everything by moving diverters and such.
If you had to do anything special when the spa was delivered new - as in priming pumps by opening drain valves or loosening pump unions keep those steps in mind. Assuming you had to tilt your spa to move it, you may have to repeat those priming steps or not.
And then get the thing hot and get in! Be aware that rubber duckies which have been out of water for than length of time may be crabby at first.
Auto: You have a beautiful back yard area. Everything looks great. What part of the country do you live in? Good luck with getting back into the tub. - Ron
Chas,I know what you're referring to/thinking.......
The 2003 Caldera Geneva Utopia didn't have the closed rotary jets. I did see em installed on the 04's on up. The difference too with the "versa-sauge" jets between the 03 and on up is.....the valves on the 03's are built within the jet itself,the 04's on up,the valve is controlled on the outside ring of the jet housing.
I did switch out if I recall,20+ euro jets,with the euro-pulse/spinnin jets.
I think I bought a few of em from you Chas It was either you,or Bruce,from Hotsprings on the east coast here in FL.
As far as renting out a room,we do have a spare bedroom,all I require is that the female staying with you is at least a 7...and will use the spa(using a bikini naturally) at least every other day
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
