We did it, we put in an order for a Jacuzzi J-345. In preparation for our new tub, we are expanding our patios and creating a separate pad for the hot tub itself. A little background, I'm trying to hide the tub. We have a very nice landscape that we have done ourselves. My wife is in the horticulture industry and is very concerned about the look of the hot tub. So I'm setting it next to the house on one of the sides and we are going to landscape on two sides of the tub. The only angle you will see it is from the entrance to the tub which is to the back/far-side as you approach. From our patio you won't be able to see it. To get to the entrance you walk around it to what would appear to be the backside/far-side from the patio.
The question is how big should we make the pad for the tub. The pad is going to be exposed concrete aggregate to match the rest of our patios. The outside dimensions of the tub are 84"X84". The bottom pan of the tub is 78"X78". Should the pad be 78X78 just large enough for the pan; 84X84 as large as the perimeter; or larger than the tub? Again 2 sides will be landscaping including large boulders 18-24" high. The lift is going to open towards the house. The tub will be 12" from the house. The lift needs 10". My gut reaction is 78X78 or maybe slightly larger, 80X80. Thanks in advance ;D
