Mineral Stick
Thisismyname
Well-known member
Joined
Jul 16, 2017
Messages
148
Reaction score
0
Are these basically the same thing just different manufacturers?
Spa Frog Mineral Sanitizer
Nature2 SPA Stick Mineral Sanitizer
https://smile.amazon.com/gp/product/B000O5Y46C/ref=ox_sc_sfl_title_14?ie=UTF8&psc=1&smid=A35H286DTCUDXL
https://www.amazon.com/Zodiac-W20750-Nature2-Mineral-Sanitizer/dp/B002IT5JS4/ref=sr_1_1?s=lawn-garden&ie=UTF8&qid=1520204518&sr=8-1&keywords=Nature2+SPA+Stick
Slightly different, but same concept.  Frog is compatible with chlorine and bromine, Nature 2 chlorine only.
What actually is in them and is there a way to refill them?  I know the spa frog is technically not reusable, but I open my bromine ones and put new tabs in them and reuse them.  If I found out what was in the mineral one and could purchase the stuff in bulk, I could also refill the mineral spa frog ones (which are expensive)
This is just my personal experience, but given how expensive they are, I do not recommend them.  I went out and bought a $5 floater and put my own 1" bromine tabs in it...I stopped using minerals and have not noticed any difference in bromine usage or water quality.
Hmmm.. that's good to  know, thanks.  The though crossed my mind.  I know they say to replace them every 4 months.  I got my tub up and running at the beginning of Nov 17 and the cartridge still has stuff in it (took it out and shook it to confirm).  I'm assuming its suppose to deplete itself, which is when I was going to replace it.  Or does it always have some level of insoluble material in there...?
I also looked at the other mineral sticks, but the price is inline with the frog brand..so there was no real savings
Cartridges are not refillable.  There will also be minerals in the mineral cartridges even if they are a couple years old.  If you are using the spa frog bromine cartridges, they technically are not reusable either.  If you are opening the cartridge and putting bromine tabs in then I would just get a floater.  Bromine tabs are not what they come with and will dissolve at a different rate.
I understand, however opening them is actually really easy.  I have found that bromine levels have been higher in the tub with the cartridge set at the same setting as I used with the spa frog chemicals (3)....so I just knocked it down to 2 and it seems to be working fine.  Prefer not to have something floating around in tub when there is something built in to handle it.
I think you are missing the point of the mineral stick.
Our tub came with a inline frog system and ozone and we started with bromine. I tried a floater dispenser for a while and also opened the cartridge and added bromine back and adjusted the flow rate and it worked fine and was much cheaper. I figured what difference could there be if the sanitizer level remained the same with it floating in the water or the water trickling thru it. I ran out of the minerals and never thought they did much and stopped using them and noticed no difference.
We had a little problem with bromine and itchiness and I thought I would switch to dichlor. As I use the tub every day and check the water I didn’t see it being any less work adding the dichlor. I now add dichlor after a water change and once the stabilizer reaches a good a number I switch to household bleach (Clorox). The only problem with this system was going away for a week or two. I now buy @ease chlorine compatible canisters good for a month. Open them up dump the @ease into a marked jar and then add just enough in for how long we will be gone. Stick it in the inline feeder and turn the water temp down after giving it a shot of chlorine as normal.
For me it is the cheapest way to keep the tub happy.
I fear. I may have to switch off bromine due to skin issues...and I say fear just because it seems like more upkeep. I don't use the tub everyday nor want to check it everyday. The @ease thing makes it easier, but just like with bromine ones, I'd prefer to be able to open it up and refill it to cut costs
Convenience comes at a cost.  I have good luck with @ease.  I have customers use it in two different ways.  Some will rely almost entirely on the SmartChlor cartridge and as such will have it at a higher setting and have a shorter life.  others will use it more as a backup at a lower setting, supplement with chlorine as needed, and get a longer life out of the cartridge.  Under no circumstance would I ever try to open up the SmartChlor cartridge and refill it.  Di-Chlor will dissolve really quickly and Tri-Chlor tabs will void your warranty.
Which begs to question..what is in it. Only a matter of time before it can be replicated (at least with a refill product).
All I use is one bag of trace mineral at each site. No crazy mixes - just put it in the right place and youll have a hole in the ground.
The @ease is a form of Di-Chlor but it is a proprietary blend.  DCDMH is what it is called and there is no buying in bulk to game the system.  But the floater is a 2 parter that will last approx. 4 months and the total cost should be close to a Spa Frog/Nature 2 system.
The point of @ease is to have approx. 0.5ppm FREE CHLORINE with a TOTAL CHLORINE at 10-15ppm.
If you're getting a rash, regardless of what santization system you are on, you're not meeting your sanitizer needs (you don't have enough in, so bacteria gets into the pores and causes the rash).
**EDIT:  For clarification on @ease floating system**
My bromine levels are always right where spa frog says they should be..so how could that be true? Established an initial reserve..shock once every week or two and the level stays at about 1 or a lil higher
First off- I apologize.  I discussed @ease and didn't realize you're asking a different question for Spa Frog.  Its important for me to note that Spa Frog and @ease are two different mineral systems from the same parent company (King Technology).
Thus:  If you're talking about Spa Frog, you're talking about a mineral system that is Bromine-based.  If you're talking about @ease, you're talking about a system that is chlorine-based.  Thus the question is:  Which one are you on?  From there, what is the level supposed to be from the manufacturer?  For instance, any generic test strip for, say, chlorine systems may want your chlorine to be at 1-4ppm.  But if you're on a mineral system, you may only need 1ppm or even less.  So the strip may say up to 4ppm, but its a generic test strip, whereas Nature 2 or @ease may call for significantly less.  You can use generic test strips, no doubt, but you need to know that their "OK" range may not be what is needed for your system.
Does this make sense?
Additionally- Your usage may also play into how much of your sanitizer is being eaten up, and thus what levels are left in your water.  Additionally- It never hurts to take your water to a pool/spa store for a second opinion.  This helps check to see if your strips are bad or have somehow become compromised.
Other issues that may be in play:  How old is your water?  Does it need to be changed?  High TDS levels can cause your specific issue.  Furthermore, your cartridges could just be old.  The mineral side only lasts 3-4 months and the bromine side or chlorine side can only last a month usually.  If they sat dry they usually can go bad.
Let me know about these questions and that can further clarify your situation for better answers from forum members.
EDIT:  Grammatical Errors Were Corrected
I currently use the spa frog bromine cartridges which I have manually refilled along with the spa frog mineral cartridge. They say to keep the bronine level around 1 as long as using the mineral system, so that's what I do. Only add stuff for the occasional shock and a little bit each time I use the tub. I've though about converting to a chlorine base regime because I've had soon issues, I just haven't nailed down the root cause yet which is why I haven't switched.
I'd increase the amount of Oxidizing Shock (MPS) used weekly.  This will increase the effectiveness of both the bromine and silver that are currently in your tub.  The amount of shock needed is relative:  Variables include how many people are in the tub per use, how long you're in there, and how many days a week you're in it.
The rash / irritation evolves from sanitizer levels not equating to the usage.  In most cases, the recommended sanitizer levels will suffice.  However, if the usage is higher than average, a higher sanitizer level may be required.  But first I'd advise you increasing your shock amounts and frequency for a spell.
Sorry if this is convoluted.  It just takes a lot of info and data to understand both the issue at hand and the variables involved.  I hope this helps.  Good luck moving forward.
I appreciate it.  I'll try doing that.  I do add a tablespoon of MPS (OxySpa) after each use (or chlorine sometimes)...in addition to shocking.  The water does seem crystal clear, though I know thats not all telling.
Back
Top
