10 year old Grandee has a slow leak. Loses about 2-3” of water a week. Dealer said they would have to take it into the shop. Anyone with experience with this?
Well, that is for the convenience of the dealers tech. Water leaks can be tricky especially in a full foam tub. I'm sure they want to charge you for removing and reinstalling the tub as well as the cost to fix it.
Have you got any idea where it's leaking from? I would open it up and pull the panels to look for the leak. It could be a jet, it could be a line in the tub, pump, etc. If you can find the source, it might be an easy fix.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
