How old is old
Aggie67
Member
Joined
Jan 20, 2009
Messages
5
Reaction score
0
I have a Calspa that has a serial number that I traced back to 1981.  I bought the house 2 years ago, and I'm just this week starting to notice issues here and there with leaks and fittings that are snapping off.  Not to mention the floor is completely rotted away.
My son and I are planning on rebuilding the thing this spring.  Everything seems to be in great shape except for the wood.  I was also toying with the idea of enlarging the shell (someone in my area is selling a unit for a song but the guts are shot, says the shell is in great shape).  My unit fits 4 adults in comfort.  This shell I have my eye on sits 7-8.  I'm a contractor and an engineer, so nothing about this swap scares me.  I've even toyed with the idea of building an in-ground concrete spa.
My question is how old is old?  How old does a spa have to be before you remove it from life support?  Other than the wood and a busted fitting, I haven't experienced any problems (he said, before the hot tub got swallowed up by a massive sink hole...).
But how old does it have to be before you take it out to the shed and shoot it?  Or do you nurture it as long as you can get it to go?
Your question cannot be answered as a general question, some brands are old and done at 5-years some at 10...
For Cal I would say 5-years.
Thanks.  Now I'm confident I'm doing the right thing.
Welcome to the forum. Good luck with the project.  I'm sure you will find good advice here.
If you want a spa project I'd start looking at Craigslist and find somone who wanting to get rid of a decent spa at a good price that maybe just needs a little work (you can find good deals like that if you're patient). I wouldn't put time or money into a spa made in 1981 that is having issues.
"some brands are old and done at 5-years some at 10...
For Cal I would say 5-years"
Wow my wonderful, beautiful Cal will be three years old in a few months...
guess the clock is ticking down....the end is near!....LOL
Did I hear that right?  It's a 27 year old Cal Spa?  If so, it may be the ONLY one...LOL.  Seriously, it is time to take it out back and shoot it...
WOW! Am I glad that I bought a Hot Springs.  :)
I just gotta say that even though I didn't care for Chuck Hewitt and his tactics in the old days, he knew the business.
I can tell you that I've seen quite a few old Cals like that over the years but still have never seen a Sundance, Jacuzzi or even Marquis that old.
I've seen very few HotSpring dog dish's (classic's) that old and a few HS personal spas that were still around with their 2-4 jets and no curb appeal but I’m not sure they were over 25 years.
Arctic, Master and several other brands represented here can't even claim spas half that old because they've not been around that long.
Give credit where credit is due.
I will tell you that I’ve sold two Marquis that I refurbished that where over 20 years old and looked new when we delivered them.
last but not least...when I saw the title of this thread I thought they were talking about Dr. Spa!! ;) ;D :D 8-)
Be VERY glad you're 1000 miles away from me  >:(
;D ;D
;D ;D
because age and deceit always win over youth and skill, or because your just a darn good shot with a stapler....? :-?
I have to figure out to post pics.  I'll show you what I'm up against.
Very easy to do and please do share with us.
Upload the pics from your camera to your computer. Then go to photobucket.com and open a free account and upload your pictures there from your computer. Once you do that, copy the image code and then come back here.
Once you reply in this thread, you will see a button at the top, third from the left that will say "insert image". Put what you copied between those brackets and you should be good to go. Let me know if you cant figure it out.
I guess that worked pretty well.
The serial number on the heater element says S186.  Calspa told me that was a 1981 number.  I don't have a manual for it.
I can't bring myself to ditch this just because of the wood.  I'll make a new shroud, and put a concrete pad under it.  Right now it's sitting on what looks like 8x8 PT lumber, which is the same stuff the retaining wall in front of the pool is made of.  One of my neighbors said the original owners had the thing inside the addition (which you can see in the last pic, taken a day or two after I moved in 2 years ago), then they turned that into a neat bar area and moved the spa under the cabana section of the addition, and then when the pool went in about 10 years ago they moved it to its current spot in front of the pool.
I pressure washed all the wood in the backyard this past summer, and it cleaned up really well.  And like I said other than a few leaks in the piping, it works.  So I think I'm going to redo the shroud and do a pad
Earlier you'd said "I'm just this week starting to notice issues here and there with leaks and fittings that are snapping off." which is why I’d questioned putting time and $ into it.
If it’s really just mainly the wood and you're up to the task then go for it but from those pictures I would DEFINITELY look to insulate that a LOT more. At a minimum get some of the foil backed foam board and attach it to the back of the panels and fill gaps where you can.
I agree with the unreal one. No insulation means big dollars in cold weather.
I just took a much younger Cal to the dump - rotted wood and a rat had chewed it a bit. Here are my guys taking the last piece of it out of the gazebo and on to the truck for it's last ride.
8-)
CRAP.   >:(
Looked out the window the day before this last cold snap and whammo, the cover was blown off and the tub was empty.  Another cracked fitting, and everything leaked out.  Got the parts today to repair, but I'm not sure the rear pipe survived the cold snap.  I've got a feeling it's all toast.  I disconnected the pump, filter and heater and drained them all prior to the deep freeze, but my guess is the pipe I couldn't drain properly is all shotski.
Dang it.
Back
Top
