Hot tub pad
Have not used them.
What is it about these that you find attractive?  You still have to do the site prep.  You have a stable level surface.
Likely to be less expensive than concrete, for sure.
Basically it is a big pad.    When I had a blow up bubble spa I put it on those interlocking square foam pads you put on a shop floor.  Same idea.  Worked great.
Back
Top
