Green water
ChrisDK
Member
Joined
Jul 7, 2013
Messages
9
Reaction score
0
Had the tub for 3½ months now, it's used every day, chlorine added after use and shocked once a week.The water is tested every 2nd day. I have also cleaned the filters on time every month.
For the first 2½ months no problems, chlorine added every day, PH down when needed and non chlorine shock every saturday.
I ran dry of the original chlorine granules so changed over to another brand as I couldn't get the same, I noticed after a few days that now instead of PH rising, it keeps dropping so I have to use PH up.
Over the last week the water has started to go green, and as it has been over 3 months now is the time to change the water.
I changed the water yesterday and all was fine this morning, so I adjusted the PH, left it 30 mins and added a good dose of chlorine granules.
Came back to it 2 hours later and it's greener than ever!!
I am thinking maybe I haven't been adding enough chlorine over a long period and now have algae in the pipes.
Normally I add enough chlorine to get to 2ppm but if I test it 12 hours later it reads 0, I thought the ozone was breaking it down.
I have shocked it and added clarifier, so if the water clears up should I ditch it, refill and clean the filters?
Here's how it looks now
Green water is usually not enough sanitizer.
Yes, ozone does break down chlorine among other things. Personally speaking, I'm not a big believer in ozonators. I used to use one and have disconnected since saw very little advantage in them at all.
Has the use of your hot tub increased? More users and/or increased usage of a hot tub will result in the chlorine being spent faster which of course means you need to put more in.
I would shock the heck out of it until the water is clear (a couple days to a week). I would also increase your 2ppm to at least 3 (the recommended is 3 to 5... and I don't for a minute believe this 2ppm stuff if an ozonator is present)
You also mentioned that you're shocking with a non chlorine shock. If you're using dichlor for your regular maintenance then you should probably also use dichlor for shocking. At least I find it a lot easier and more reliable.
Thanks Bob.
The water is now looking clear again after more chlorine and shock.
I will clean the filter tomorrow and make sure I keep the levels a little higher.
Back
Top
