OK y'all - I need some advice. I've got cloudy water again, and I seem to be on a repeating cycle with this problem so obviously I've got a piece missing from my water management puzzle. Here's the scenario:
My water starts out crystal clear and stays clear while in use. Then after a time the water will be perfect and clear until its in use and then while the jets are on the water will become completely opaque with zillions of tiny bubbles (almost like the water is carbonated and by opaque I mean it practically looks like I'm sitting in skim milk). There is not an issue with surface foam, and once the jets are off the water will return to a crystal clear state after a few minutes. No off odors to report. No scum line or any deposits visible on the tub. It will stay like this for a while and then at some point I open the cover to find the water cloudy and I can't get it to clear up. I then give up and change the water. I'm on my third water change. The first fill and my current fill both seemed to develop the problem between 3-4 weeks. The 2nd fill lasted 2 months, and never really got cloudy but the water was getting opaque again and I could tell it was coming so I went ahead and changed (only difference with this fill was that the second fill I was using an after-market filter, 1st and 3rd use the Marquis filter). I had attributed the improvement between the 1st and 2nd fill to my improved knowledge on water balancing, but now that my issue has returned so soon on this fill, obviously that wasn't it. We shower before using the tub and swim suit soap isn't an issue and no one else uses the tub.
Tub is a Marquis Spirit 200 gallon tub w/ ozonator and built in spa frog dispenser
my routine
In-line Spa Frog (bromine and mineral cartridges)
Non-chlorine shock once a week
test strips a couple of times during the week to make sure nothing out of whack
test water every weekend (the water seems to stay pretty well balanced - the only thing I really need to adjust is raising the calcium hardness (its starts out really low after the fill and seems to take a lot of hardness increase to bring it up--like double what the package says I should need) and sometimes raise the TA a bit which will drift down if I leave it on its own.)
I use Spa Pure brand products.
Here are my current readings from a spa dealers tester:
Total Bromine - 12.3 (but I had really shocked the heck out of it yesterday trying to clear the water) it's usually around 1.
pH - 7.8 (usually ranges between 7.6-7.8 on my tests)
TA - 94 (usually ranges around 70s-80s on my test and this takes chemicals to keep it in the 80s otherwise it will drift down)
CH - 250
Copper - 0.1, Iron 0.2
The first time I had the cloudy water my TA was 25 (that was before I had bought my own test kit) and raising it improved the cloudiness but it didn't cure it. I had thought maybe that was the problem again and I was getting inaccurate results from my tester but my TA and PH were both inline with the dealer results.
The dealer was a little at a loss since my numbers were pretty good and she told me to run the tub a couple of hours without the cover this afternoon and see if it clears up and bring in another sample tomorrow. So ..... do any of you have any ideas in the meantime?
my routine
CH - 250
