Original
heater is leaking
Pages: [
Topic: heater is leaking (Read 2581 times)
GILBERTA
Junior Member
heater is leaking
on:
May 25, 2007, 03:42:11 pm »
I have a leak were the heater is. I then turned off to the hot tub and it stop leaking
heater is leaking
on:
Pathfinder
Full Member
Re: heater is leaking
Reply #1 on:
May 25, 2007, 03:51:08 pm »
check to see if the unions are tight enough around the housing they may not be tight enough cross threaded or the gasket is cracked or pinched.
Gary
Full Member
Laugh daily you will live longer
Reply #2 on:
May 25, 2007, 04:11:00 pm »
Lots of places water can leak at the heater:
1. Check union gaskets (replace)
2. Pressure Switch (replace)
3. Heater studs (replace heater)
4. Heater housing (replace heater housing)
Most of the the time it is either the studs or pressure switch.
GILBERTA
Junior Member
Reply #3 on:
May 25, 2007, 05:43:19 pm »
looks like the housing is cracked the housing around the heater. Can i just buy a housing or can i just epoxy it
GILBERTA
Junior Member
Reply #4 on:
May 25, 2007, 05:48:16 pm »
also were can i get one Thanks for all the help. Do i need to drain the tub to fix this
Reply #4 on:
Pages: [
Original
heater is leaking
