Author Topic: low PH and TA  (Read 2625 times)
H823Putt
  • My backyard oassis
low PH and TA
« on: May 20, 2007, 06:09:42 pm »
If your PH and TA are on the low side, what would be the best way to get them both up without going nuts. I do not want to start adding increasser then decreaser then increaser and on and on and on......
low PH and TA
Re: low PH and TA
« Reply #1 on: May 20, 2007, 06:40:55 pm »
First adjust TA with Baking Soda (TA Increaser).  You need to know how much to add by testing.  Once you know your reading and your goal, find a table that tells you how much to add.  Of course you need to know how many gallons you have.
Once you have TA where it needs to be you may have to adjust pH.
Re: low PH and TA
« Reply #2 on: May 20, 2007, 07:06:22 pm »
I find using baking soda raises both TA and PH ... you may find that too!
H823Putt
Re: low PH and TA
« Reply #3 on: May 20, 2007, 07:12:06 pm »
Thanks for the info.  :)
Re: low PH and TA
« Reply #4 on: May 20, 2007, 07:48:10 pm »
The Baking Soda will increase both.  If you want to just raise pH, use pH Increaser (soda ash).
Re: low PH and TA
