Actually 50 years ago it was the jetted bathtub. The spa business is not 50 years old.How do you know the accuracy of 80,000 spas a year?Yes, the ozone runs with the circ pump. Always on except when jet pump running, as with most Sundance/Jacuzzi products.
1) Find out whether that ozone that they inlcuded is UV or preferably the CD type.2) 80,000? Where did you find that number? C'mon, I'm not so sure I buy that!!!
The ozone is of the corona discharge type, all of their spas contain a built in line ozone injector, the CD unit is optional but according to my dealer, they install them in house on every Jacuzzi they sell without the "optional price"...Please read my previous post on the factory capacity of 300 spas a day...I should say I mispoke when I said they manufactured over 80,000 spas worldwide, I should have said the plant in California maunfactured over 80,000 spas for sales worldwide.
Interesting. Watkins manufacturing, which sells the most hot tubs, says this:" Watkins has manufactured more than 650,000 spas since its inception over 25 years ago." That works out to be 26000 hot tubs per year.
You have to factor in the early years when they were making 1st hundreds, then 1000's.
Absolutely.But my point is (reinforcing yours) that the 8000 year number is crazy and 300 per day capacity was probably pulled out of some marketing assistants butt. IfWatkins, which represents several lines, and sells the most tubs, has only put out half a million in 25 years, I doubt Jaquzzi has not even come close to makeing 300 a day. That capacity number is fictious.
They make 200 hot tubs a day? Not stamping out "spa shells" (which could be anything and any size) but complete full sized plumbed spas? Assuming round the clock shifts that's a complete hot tub every 7 minutes or so. That's ALOT. I find it hard to belive??
