Author Topic: I'm back....gotta a question  (Read 3427 times)
cappykat
« on: May 03, 2007, 02:28:55 pm »
Hi gang!  I've been off doing other things...like getting our house remodel done. Finally, the bathrooms are done and the hardwood floors are down.  Backyard looks awesome and we have some tiny projects left, but otherwise--we're done! How's everyone?
Gotta question...we're going to empty the hot-tub for the summer.  We just aren't using with any regularity.  I know to keep it covered to protect the shell, but how do I get all the water out of the hoses, etc. so bacteria doesn't build up there?
2005 Marquis Epic
Bonibelle
  • '05 Marquis Epic
Re: I'm back....gotta a question
« Reply #1 on: May 03, 2007, 02:42:36 pm »
Welcome back, We missed you!!
« Reply #2 on: May 03, 2007, 02:43:31 pm »
Hey, post some pics of the remodel!
You can use a shop vac to suck out the last remaining water from a tub.
« Reply #3 on: May 03, 2007, 03:14:29 pm »
Yup- shop vac.
Put the nozzle on each jet.
I was amazed at how much water I got when I did that.
It was several gallons- at least 3.
« Last Edit: May 03, 2007, 03:15:15 pm by Brewman »
Gary
« Reply #4 on: May 03, 2007, 03:18:16 pm »
It will be almost impossible to get all the water out, but if you shock a day before you drain and then of course shock when you fill it back up it will be fine.
Gary
« Reply #5 on: May 03, 2007, 03:20:07 pm »
Tip the spa on it's side and shake out any excess water.
How expsoensive can it be to run the spa with water though for few months? IF no one uses it during the summer, it should be very cheap.   Might be more work to empty, clean and refill it and another chore to do in the fall?
« Last Edit: May 03, 2007, 03:21:37 pm by drewstar »
cappykat
« Reply #6 on: May 04, 2007, 12:04:44 pm »
Thanks for the tips.  It's at that point where the water needs to be changed, so just figured we'd empty it and wait til fall or fill as the need arises.
Drewstar..."tip the spa on it's side..."
Geez...why didn't I think of that.  Thanks!  ;D
2005 Marquis Epic
cappykat
« Reply #7 on: May 04, 2007, 12:19:34 pm »
I'll post some pics but I don't remember the image place I used before.  Give me some sites to try.
2005 Marquis Epic
Chad
  • 2006 Jacuzzi J-345
« Reply #8 on: May 05, 2007, 08:49:29 am »
http://www.photobucket.com
