Author Topic: Run jets or not  (Read 1537 times)
The_Pa._Lady
Run jets or not
« on: April 07, 2007, 09:45:50 am »
We were away for 3 weeks, the water looks fine.  I need to check it, I'm sure by now it needs some kind of chemical.   In your opinion, would you check it before running the jets, or run the jets first for awhile and then check it?
Thanks for your feedback.
Run jets or not
Re: Run jets or not
« Reply #1 on: April 07, 2007, 10:04:51 am »
I would check the PH and if it's OK, I would shock the water if using bromine or add about 6 PPM chlorine and run all the jets for a full cycle. I would test for sanitizer after the cycle and if you still have free bromine/chlorine then you're go to go. If you don't then add more shock/chlorine and repeat until you have free a sanitizer reading.
If you shocked the water before you left you really may be OK after the first treatment.
« Last Edit: April 07, 2007, 10:05:14 am by Vinny »
Re: Run jets or not
