Author Topic: Sundance Stereo  (Read 3284 times)
Gary
Sundance Stereo
« on: March 21, 2007, 10:58:36 am »
Looking for some feedback on the failure rate on the stereo Sundance uses on their current spas. I am not trying to stir up anything, I think the system sounds good but my experience with in deck/cabinet mounted stereos on spas is not good.
Sundance Stereo
Re: Sundance Stereo
« Reply #1 on: March 21, 2007, 11:24:29 am »
The stereo in my 2003 Optima is still working as it did when new.  That's thru 3 Minnesota winters.  Speaker sound is crystal clear.  Overall I'm extremely impressed with this setup.
  The stereo unit itself is made by a company called Poly Planar, they specialize in marine grade electronics.
If you want to see the stereo up close, with specs, etc,  check out:
www.polyplanar.com
Look for the stereo link, and also the spa products link.
« Last Edit: March 21, 2007, 11:30:08 am by Brewman »
AAAAAAA
Re: Sundance Stereo
« Reply #2 on: March 22, 2007, 08:14:52 am »
In our Maxxus, the sound cuts in and out, really enoying.
I have to power off the system and turn it back on for it to work at normal volume for a while. Hopefully the dealer will come in and fix it this summer.
wetone
Re: Sundance Stereo
« Reply #3 on: March 22, 2007, 08:34:54 am »
How long have you had the Maxxus?
Does the stereo only cut out if you turn the volume up?
AAAAAAA
Re: Sundance Stereo
« Reply #4 on: March 23, 2007, 10:29:38 am »
I purchased it in spring of 2005.
It started happening spring 2006. It cut's out regardless of how loud I am listening to it. It doesn't cut out completely, it just gets really low volume where you can barely notice it is still on. The only temporary fix is to power off and on. Then I get another few minutes of music heh.
I am sure it will get fixed soon. I am not concerned.
lpbo1
Re: Sundance Stereo
« Reply #5 on: March 23, 2007, 08:04:49 pm »
Hello just had the spa tech out here to look at my sterero on my cameo, Tech told me sometimes the ozonater will cause feedback to the stereo . Makes  the volume go up and down with out any input, The fix is to move ozonater away from stereo, This is coming directly from sundance. Also he removed speakers and found the connection to be corroded , cleaned up both sides works great. sorry for the sp. Hope this helps
Re: Sundance Stereo
« Reply #6 on: March 23, 2007, 08:54:48 pm »
How old is your spa/stereo?  Was this work warranty?  Just curious; not trying to create a scene.  Most spa stereos have 1 year warranty regardless of the warranty on the rest of the spa.  Many dealers will eat a service call like that when spa is shortly our of warranty. :-?
Re: Sundance Stereo
« Reply #7 on: March 24, 2007, 08:57:46 am »
IIRC, the warranty on the Sundance stereo is one year.
ndabunka
Re: Sundance Stereo
« Reply #8 on: March 26, 2007, 03:13:59 am »
Sundance and Jacuzzi Stereo's are identical so...No problems here with my 2003 J-370 stereo/CD either.  Also a Planar head end and pop up speakers.
« Last Edit: March 26, 2007, 03:14:36 am by ndabunka »
SerjicalStrike
  • Reinstate Hank Williams!!
    • Great Bay Spa and Sauna
Re: Sundance Stereo
« Reply #9 on: March 26, 2007, 08:47:00 am »
The stereo system on a Sundance has a 2 year warranty.  The ozone system has a 1 year warranty.
Re: Sundance Stereo
« Reply #10 on: March 26, 2007, 11:46:33 am »
Do they put the subwoofer in the Jacuzzi now?  They didn't before.
Re: Sundance Stereo
