Author Topic: Arrrgh!  Darn Chemicals  (Read 6513 times)
mader
Re: Arrrgh!  Darn Chemicals
« Reply #15 on: March 21, 2007, 12:32:26 am »
Brentp,
Just following up on my earlier post.  I did ditch the taylor kit and rely on the strips.  However, what I found out was that my water (Atlanta) needs a lower TA than then "recommended" in order to get my PH right.  I believe I have seen other posts here that suggest that is the case for some.  The thought is that PH is more important than TA.  If you can stablize your PH at a TA level below "recommended", then you are good to go.
