Author Topic: New Ozonator, Should I or not  (Read 2736 times)
twok99
« on: March 12, 2007, 01:27:47 pm »
I have a 2003 Jacuzzi Premium J-370 and the ozonator has stopped working.  Should I bother replacing it?  If so, what are your recommendations.  I will be doing this myslf since the ozonator is out of warrantee.  Thanks.
Re: New Ozonator, Should I or not
« Reply #1 on: March 12, 2007, 01:33:12 pm »
since it's out of warenty, why not wait a bit and see if you notice a difference in water quality.
If you expereince no difference, then I'd say "Why Bother?".
« Reply #2 on: March 12, 2007, 01:50:02 pm »
How do you know it stopped working?
twok99
« Reply #3 on: March 12, 2007, 02:36:01 pm »
1 - no more bubbles
2 - ozone icon light on control no longer lights up
3 - no more hum from ozonator
4 - discussion win Jacuzzi tech support regarding above
« Reply #4 on: March 12, 2007, 02:42:48 pm »
No water quality issues?  do you typically leave your spa unattended for several days?
Tatooed_Lady
« Reply #5 on: March 12, 2007, 04:05:54 pm »
I thought bubbles didn't necessarily indicate ozone present.....unless you mean the whole thing took a dump, in which case...I guess that would make sense. Could it be a loose or corroded wire, though? My thoughts on most things (unless it's something I don't like and want to upgrade from anyhow) is "start with the cheap fix", and work up from there....
Best of luck!
RIP C-Rod
« Reply #6 on: March 12, 2007, 04:20:00 pm »
 You should still have bubbles regaurdless of ozonator not working, possible bad check valves as well should be 2 there.
 As others have stated its up to you to replace if you notice a difference.
