Author Topic: Back to the Tiger River Bengal  (Read 2152 times)
cak224
« on: January 23, 2007, 03:18:26 pm »
I've pretty much decided to get the Bengal.  Just unsure of a few things?
1).  2007 bengal but quoted as a series EE.  What does that mean.
2).  Suppose to be a 220 but is that a converted model (from a 110).
3).  Another dealer said to be sure its a mmj1 series.  Any one know what that means?
Price I was quoted was 2207 EE bengal 6000 + tax
ozonator inc
steps 36" inc
cover valet easy lifter inc
chemical kit inc
thermal lid inc
gfci  incl
Help an spa-ly uneducated man.
Re: Back to the Tiger River Bengal
« Reply #1 on: January 23, 2007, 05:21:27 pm »
The "M" denotes the convertible spa - that is the Model designation. It will run on 110 or 220 with a simple conversion. The Tiger River Bengal with the model designation "MM" is the 220-only model. MM spas have a larger jet pump so you can run more jets at the same time. Not more jets, not more power from the jets. Just more jets at the same time. The plumbing is different to allow for this.
They are both considered "EE" series tubs. That means Energy Efficient. That denotes the smaller jet pumps (in this case only one jet pump) and the larger, 5000 watt heater. Some of the other models have the "HP" designation - monster jet pumps and a 4000 watt heater. The HP tubs also have the Tri-X filters in the HotSpring models. Not needed in TR because they are bypass filtration tubs.
Also - the MM model tub comes with the "Amur" waterfall feature - and a two-speed jet pump.
Here is the info from the web site:
Control System
Convertible      IQ 2020; 115v/20 amp, (includes G.F.C.I. protected power cord. Or 230v/50 amp, 60Hz)**
Heater
Convertible- No-Fault(R) (1500w/115v or 6000w/230v)
Jet Pump
Convertible       Wavemaster(R) 7000
(1.65 HP Continuous Duty,
 3.5 HP Breakdown Torque)
Control System
Dedicated       IQ 2020; 230v/50 amp, 60Hz, (includes G.F.C.I. protected subpanel)
Heater
Dedicated- No-Fault(R) (6000w/230v)
Jet Pump
Dedicated       Wavemaster(R) 9200
(Two Speed, 2.5HP Continuous Duty
 4.8 HP Breakdown Torque)
Water Feature       Amur(R) (backlit with blue LED lighting)
cak224
« Reply #2 on: January 23, 2007, 06:20:45 pm »
Thank you Chas, for taking the time to explain it to me.
« Reply #3 on: January 23, 2007, 09:20:08 pm »
My pleasure. Enjoy your tub!
Post some photos if you get a chance.
And we are here to help once it's delivered and you have questions about water care.
 8-)
