Author Topic: Jacuzzi J470 Ozone Question  (Read 3841 times)
bwbski22
« on: January 16, 2007, 03:19:16 pm »
I was wondering when the ozone runs?  does it run whenever the pumps are off?  or does it run durring the filteration Periods?
Chad
  • 2006 Jacuzzi J-345
Re: Jacuzzi J470 Ozone Question
« Reply #1 on: January 16, 2007, 03:31:06 pm »
I have a '06 J-345. The ozone runs 24/7 w/ the circ pump unless the water reaches 2 degrees more than the set temp. It also shuts off if your tub reaches 105 or higher.
« Last Edit: January 16, 2007, 03:56:21 pm by WHY_NOT »
« Reply #2 on: January 16, 2007, 03:49:07 pm »
 The ozonator does not run when main pumps are running, it will however run when the spa is in a filter cycle,and when the spa is not in use.  When you use your spa and hit a pump btn it shuts off but will come back on approx 5 to 10 minutes after the pump has shut off.
 The 470 is a little different, it really doesnt need to run a filter cycle as the circ pump filters approx 50,000 gallons a day.   Pump 1 draws through a suction and pump 2 draws from the suction fitting on the floor (looks like a drain)and filters thru the polishing bag filter.
  We had a 470 running at the fair this last year and sometime during the night a few carnnies got in the spa,there was about a pound of sand and dirt in the btm of the spa. well we ran pump 2 off and on within a few hours the sand was gone and had deposited into the polishing bag I was pretty amazed.  It did a really great job of sucking it out.   Try that with a nobypass filter system.  :o
bwbski22
« Reply #3 on: January 16, 2007, 03:53:34 pm »
so my ozonator should be running whenever the circ pump is on, and after a time period of 5-10 minutes after the last button was hit?
Chad
« Reply #4 on: January 16, 2007, 03:58:29 pm »
JJ, I could have sworn I saw bubbles coming out of the ozone port when my pumps were on. I guess I was wrong. I'll keep an eye out tonight during my soak.
Thanks,
Chad
« Reply #5 on: January 16, 2007, 04:01:34 pm »
  Yes!!
« Reply #6 on: January 16, 2007, 04:06:09 pm »
Thanks,
Chad
 Just because there are bubbles it doesnt mean there is ozone, when the circ pump is running 24/7 it is still drawing air thru the ozonator via the bohls/mazzi injector and squrited out the warm water return jet. Most spas run this way.
 I think D1 is one of the only ones approved with a no off gass system that is allowed to have the ozonator run when in use,I could be wrong on that not sure.
anne
« Reply #7 on: January 16, 2007, 10:04:15 pm »
My arctic's ozone runs whenever pump #1 is on, which is with all filtration cycles and when in use.
Dance like nobody's watching
