Author Topic: Too Much Chlorine??  (Read 3896 times)
Spiderman
Too Much Chlorine??
« on: January 13, 2007, 12:01:10 am »
When I shock my tub once per week I use 3 tbls of dichlor for a 225 gallon tub.  This dosage should bring it up to about 12ppm.  24 hours later, the FC level is still high; around 5+ppm.  Is this normal??  Or should I use a diff amount of dichlor??
Too Much Chlorine??
Gomboman
  • My Pride and Joy
Re: Too Much Chlorine??
« Reply #1 on: January 13, 2007, 12:07:40 am »
Wow, that is a lot of dichlor Spiderman. I use 2 tbls for a 450 galon spa and it works well for me.
« Last Edit: January 13, 2007, 12:07:57 am by Gomboman »
Chad
  • 2006 Jacuzzi J-345
« Reply #2 on: January 13, 2007, 12:19:38 am »
It really all depends on what your CC is before you shock.
Btw, if your tub has a zero FC and you add 1 TBS of dichlor your FC should be between 10-11ppm. (depending on the % of available chlorine in your dichlor)
3TBS would get your tub between 28-33ppm. :o
The formula is
gallons of tub x ppm x .000128 / % of available chlorine = ozs of dichlor
e.i.- 225 x 10 x .000128 / .57(?) = .50 ozs of dichlor (1 TBS)
« Last Edit: January 13, 2007, 12:46:12 am by WHY_NOT »
« Reply #3 on: January 13, 2007, 12:38:25 am »
Seems to me you back way off.  HS recomends 1.5 teaspoons once a week.
Tatooed_Lady
« Reply #4 on: January 13, 2007, 10:02:12 am »
for your once per week shock of dichlor, what do you have for a reading if you drop it from 3 Tbsp to 2 Tbsp 24 hours later? I wouldn't cut your weekly shock TOO far back (after all, the point is to kill off gunk in the water), but try cutting by about 1/3 and see what your levels are at. That way, you're still going to bring your chlorine levels up high enough to kill off the goo, but low enough that you don't have high chlorine levels the next day.
and if 3 Tbsp in your tub should make 28-33ppm, and it's down to 5 in 24 hours, it sounds like you still need a good shocking to keep your water clean.
Just my slightly fuzzy $.02.....
RIP C-Rod
Chad
« Reply #5 on: January 13, 2007, 11:03:28 am »
If you don't test for CC than don't try and guess how much dichlor to add? :-/
Just you mps!
« Last Edit: January 13, 2007, 11:04:40 am by WHY_NOT »
