Author Topic: Everything I've Known Is a Lie  (Read 3774 times)
Brookenstein
« on: January 10, 2007, 03:40:43 pm »
Ok, so after getting a taylor test kit, I feel like I've been living a lie the last year +.
I always thought I had perfect water, therefor my maintenance was a breeze.
Well, so is not the case.  My water is almost a week old.  We haven't used the tub yet.  My PH is >8 and my ALK is 150.  I added a cap of PH/ALK down.  How long do I wait to retest and adjust again?
Also, when it comes to FC/CC/TC when is it that you need to shock?
Pathfinder
Re: Everything I've Known Is a Lie
« Reply #1 on: January 10, 2007, 04:02:10 pm »
maybe 20 mins  to test again
one suggestion would be to test your tap water   if it has a low ph/Alk   you can always just add water to lower your levels instead of always adding chemicals
once  you add R-03  after combining R01& R02  if the colour changes then you most definitely need to shock  if not then  stay on your regular schedule
« Last Edit: January 10, 2007, 04:04:36 pm by Pathfinder »
Chad
  • 2006 Jacuzzi J-345
« Reply #2 on: January 10, 2007, 04:16:24 pm »
I'd wait atleast a couple of hours. Preferably tommorrow. You'd hate to add to much. I'd just be patient and see what it is in the morning.
Btw, ph/alk - is the only chemical that you do not run the pumps right after adding b/c it's an acid.
Taylor reccomendes when CC is .5 or greater. That's what I do.
Brookenstein
« Reply #3 on: January 10, 2007, 04:39:05 pm »
ALK went down 25, but PH is the same at >8.  Is there a way to treat just PH?
Chad
« Reply #4 on: January 10, 2007, 04:46:45 pm »
Not that I know of.
Both Dry Acid and Muriatic Acid will lower both. Each one lowers alk more than ph. So your results are typical.
Try getting your alk down in range first, preferably at or below 100 and then see where your ph goes. Add soda ash if the ph drops out of range. You could also use baking soda but that will raise your alk a little too.
« Last Edit: January 10, 2007, 05:08:55 pm by WHY_NOT »
Pathfinder
« Reply #5 on: January 10, 2007, 07:02:39 pm »
Its very simple   use your tub  and the level will drop
dont over analyse your water now that your using the Taylor kit
if your water was not having  problems while you while relying on the strips then just relax.  Way to0 many people stress about their readings to actually enjoy their tub.
« Reply #6 on: January 10, 2007, 10:59:32 pm »
That's why I'm a Test Strips guy.
And briefs, in case anyone wanted to know.
 8-)
MostlyLurkingGal
« Reply #7 on: January 10, 2007, 11:39:58 pm »
And briefs, in case anyone wanted to know. 8-)
Ok Chas, I have had enough of your statements made as if they were "facts". I'm gonna need some proof for this one!!
Gomboman
  • My Pride and Joy
« Reply #8 on: January 11, 2007, 12:31:37 am »
Brooke, that's too bad. I know you were always good at not micro managing your water. It didn't appear that you had any major problems with your old method even if your water wasn't really perfect. Oh well.  :)
My PH always stays high for the first couple of weeks after a water change and then it comes down on it's own. I've learned to live with a high PH after a re-fill.
Take Care
Bonibelle
  • '05 Marquis Epic
« Reply #9 on: January 11, 2007, 07:57:58 am »
I'm with Chas...at first I thought I needed that Taylor kit too, but my dealer said I should be fine with strips. I think if I had continued to have problems with my water, I might have gone to the Taylor kit. But since everything is good, I'll stick with the strips...
I guess the question is Just how chemically perfect does your tub need to be? If the test strips allow you to manage your water so that your tub is clean and your equipment is safe from extremes that could damage it...just how accurate do your parameters have to be?
I can see maybe using the Taylor kit after a fill to get initial levels perfect, then using strips to maintain... How much is a Taylor kit anyway?
shortspark
« Reply #10 on: January 11, 2007, 08:23:49 am »
I'm going to agree with most people here that micro-managing water and constant testing and adding this and that to the water can get out of control.  It reminds me of some of the oil geeks at an auto lubrication forum I go to now and then.  Man, you would think dumping a quart of oil in your car would be a no brainer but my God, you can't believe what some of these guys go through for optimum engine lubrication.  It can be the same thing here with hot tub water.
I've been a tub owner for 20 years (In fact, my next tub, a HS Jetsetter will be delivered at the end of the month).  At first I would check water every day with little jars of red stuff, clear stuff, yellow stuff.  Heck, you would think I was making test tube babies!   Then I would do the same thing with strips.  I would adjust to try to get my water perfect by adding this and that and the other thing and would usually screw things up worse than when I started.
Then I got smart (and experienced).  I could tell by water smell and clarity if I needed any chemicals.  I found that a little floater filled with chlorine pucks and adjusted as to flow was all I needed.  Sometimes, I could "feel" the water being too hard or soft around my body and a PH adjustment would be made but that was rare.
My case is somewhat unusual I guess as I live alone and over the last ten years I can count on one hand the number of people that have been in the tub besides me.  More frequent use and maybe my system would not work.  Nonetheless, I change water quarterly and clean filter monthly.  Heavier use and you should change water even more frequently.  That is the secret.  Get your water within reasonable range so you are comfortable and so your tub's equipment is protected and don't worry about it further - then enjoy!!
windsurfdog
« Reply #11 on: January 11, 2007, 01:20:28 pm »
The best rule of thumb I use is not testing my water but once a week...and I highly recommend it.
Chad
« Reply #12 on: January 11, 2007, 03:11:48 pm »
Some of us are just a little more particular then others. I have a taylor k-2005 and love the felling that I'm soaking in both perfect water for me and my tub. I'm FAR from a micro manager. In my 10+ weeks I've only added + or - chems twice to maintain this. I'm not saying it's for everyone but don't assume just b/c someone uses one that they micro manage.
« Reply #13 on: January 11, 2007, 03:51:18 pm »
I agree.  I test once per week.
As far as strips go...I always had a hard time identifying levels.  What I thought was a pH of 7.4 was actually about 6.8.  TA was always off also.  With the Taylor kit, I always know.
« Reply #14 on: January 11, 2007, 03:53:08 pm »
A note from Chas' wife:
Yes, I will vouch for the fact that Chas wears 'tight whiteys.'
I have discouraged him from posting a photo, although he seems to be more than willing to do so.
Mrs. Chas
