Author Topic: HELP,, Heater has stopped working  (Read 6066 times)
tvaughan
  • Hot Springs Grandee Owner
« on: January 08, 2007, 09:45:00 pm »
My heater stopped working on the 4th of Jan.  I've contacted my dealer (Hot Springs, never again) and they say they are just too busy to get here to help me out.  It's still under warranty.  The dealer has just advised me to not drain the tub but to just keep the 30am breaker off and says the circulation pump will keep the tub from freezing.  It's suppose to be 24f degrees tonight and for the next 3 or 4 days.  I'm really starting to worry about the tub freezing up.   It's a 2004 Hotsprings Grandee.
There are no lights flashing,the breakers have not poped.  The heater is just not working.  The water was at temp on the 2nd our last use.  We went to use the tub the afternoon of the 4th and found that the heater was not working.
I can't even tell if the circulation pump is working.  Is there any  easy way to check the circulation pump out.  It's about 31f out side now.
I've called the dealer again today and they still say they can't get to me.  It's 35 miles away.
I'll never purchase a HotSprings product again.   A warranty is no good if the dealers will not honor it.
« Last Edit: January 09, 2007, 12:28:39 am by tvaughan »
Chad
  • 2006 Jacuzzi J-345
Re: HELP,, Heater has stopped working
« Reply #1 on: January 08, 2007, 10:10:15 pm »
Is the whole tub shut down or is it just the heater? If it's the latter, I would run the pumps as much as possible. They will give off some heat and moving the water around will help a little too.
« Last Edit: January 08, 2007, 10:26:39 pm by WHY_NOT »
« Reply #2 on: January 08, 2007, 10:36:46 pm »
Do you have bubbles coming off the floor?
Have you tried resetting?
Which lights are blinking?
Once again we see the importance of the dealer. :(
tvaughan
« Reply #3 on: January 08, 2007, 11:01:17 pm »
   Nope,, no bubbles that I can see..
   Yes I've reset.... This happened on the 4th of Jan.
   There are no lights blinking.   The Heater is just not working...
   The breakers never cut off.
   The filters are clean.   The water was at temp on the 2nd. Last Time  Used.   When going to get in the tub on the 4th.  Heater was not working.
   yep... I've been very happy with the tub for 3years now.   The Dealer has been a problem since the week after I gave them the Second half of the purchase price.   Oh well,, I knew I should have gone with another brand..
Richs100
« Reply #4 on: January 08, 2007, 11:03:22 pm »
Where are you located?
Free advice from a lawyer?  I would fax them a letter briefly outlining what is gone on,  (IE:  heater out on the 4th.  1st call to dealer on 5th, etc)  and request they expedite their service call due to it being the middle of the winter.  In the alternative, ask that they arrange for an external heater to protect the tub until they can repair it.   I've never seen one, but I hear they exist.
Generally, I have found that once a problem is put in writing, it gets much more attention than before.  Worth a try.  And I really think they have had more than enough time to arrange their schedule to take care of emergency situations like yours.  You might also want to contact Hot Spring corporate and discuss their assigning your repair work to another dealer in the area.  So sad.
tvaughan
« Reply #5 on: January 08, 2007, 11:17:27 pm »
Thanks.. That's a good suggestion.  I did contact Hotsprings customer service this afternoon.  There hasn't been a reply except for the email saying that my request for service was being processed.
I'll fax the dealer right now.
Thanks..
« Reply #6 on: January 08, 2007, 11:31:35 pm »
And you can phone Hot Spring customer service @ 1 800 999 HOTT.
PotomacG
  • What's so funny 'bout peace, love & understanding?
« Reply #7 on: January 09, 2007, 07:46:56 am »
Didn't someone on this forum recently mention a "Bucket Heater"?
I would have one FedExed if I were you.
And as HTD just mentioned above, I would call Watkins directly and see what they are willing to do.
« Last Edit: January 09, 2007, 07:48:07 am by PotomacG »
Zep
  • Cal Spas SQ92 Dallas-Texas
« Reply #8 on: January 09, 2007, 08:34:12 am »
Is this your first problem?
How has the dealer been up to now?
If the dealer has always been responsive in the past
then it may just mean they are "swamped" this week.
Also e-mail the dealer.
Later they could claim they never got the fax, but if you can get them to
respond to an e-mail then you would have dated documented proof [/u]
of your problem and their response.
Also a letter via certified mail is good too.....but IMO e-mail is best.
Let us know how it turns out.
Good luck......(I bet HS will come through for you)
« Reply #9 on: January 09, 2007, 08:41:15 am »
Is this your dealer?
Syracuse Pool Center, Inc.
Address:
 6176 South Bay Road
Cicero, NY 13039
Phone:
 315-699-5211
« Reply #10 on: January 09, 2007, 08:42:20 am »
True, but heater problems in winter weather/locations should be top priority.
« Reply #11 on: January 09, 2007, 08:49:21 am »
What's up with the HS website?  This morning, it makes me put in all my info just to go anywhere else on their site. I hate that! :P
« Reply #12 on: January 09, 2007, 09:50:23 am »
 .... Oh well,, I knew I should have gone with another brand..
Sounds like a dealer issue, not a brand issue.  No?
Tatooed_Lady
« Reply #13 on: January 09, 2007, 09:56:03 am »
you've been happy with the tub (brand), but the dealer's a moron....sounds like the brand's not the issue, just the area rep....
I'm along on the "get a hold of the manufacturer" and "email the dealer" train....if you email the dealer and they send you an excuse back, you can forward that to watkins...maybe that'll be enough to light the fire?
Good luck!!
RIP C-Rod
« Reply #14 on: January 09, 2007, 10:01:14 am »
You might consider getting a stock tank heater or something similar that you can put into your water if you're worried about freezing before you can get the heater repaired.
  I don't think they cost too much, should run off 120V, and might let you get some sleep.
 Living in the freeze belt, I certainly consider a non heating spa in January to be a priority.
  Prime example of how a the image and reputation of a perfectly good product can be tarnished by a bad dealer.
