Author Topic: Yes... ANOTHER Shocking Question!!!  (Read 4837 times)
MostlyLurkingGal
« on: January 06, 2007, 07:54:06 pm »
I really didn't want to start ANOTHER  thread about my inabilities to shock my tub correctly, but I just can't seem to get it right, so could someone please just give me your opinion on what I'm doing wrong? I shocked Thursday night with Spa 56 Dichlor using 1 TBSP. (per bottle instructions for 250 gal. tub) Last time I used MPS, so this time I used dichlor.
JETSETTER...225 gallon (I think)
Anyway,  Here are my readings to the best I can tell ..
Taylor test kit:
FC=4, TC=7 / 8, PH =7.4 and TA=110
strip test:
FC=5, TC=7, PH...no color matched strip, and TA = 110
Wasn't the shock suppose to get rid of CC? Maybe my readings are off?
I'm at a loss...I don't think I can soak with these readings...can I?
Chad
  • 2006 Jacuzzi J-345
Re: Yes... ANOTHER Shocking Question!!!
« Reply #1 on: January 06, 2007, 08:07:50 pm »
MLG, I find it very difficult to test for CC when there is any FC present much less 4ppm. I'd let the FC go down to 0 and then test again.
It's OK to soak with a 4-5 ppm FC.
« Last Edit: January 06, 2007, 08:08:25 pm by WHY_NOT »
MostlyLurkingGal
« Reply #2 on: January 06, 2007, 08:19:51 pm »
Thanks Chad. Knew I could count on you!
Should I be shocking with less? Seems to be too much...it's 48 hours later, and still kinda high, isn't it? How long do you wait before going in after shocking with dichlor?
Chad
« Reply #3 on: January 06, 2007, 08:33:59 pm »
Your Welcome
It really all depends on your CC.
One TBS for a 225 gal tub with a starting ppm of zero and using Spa 56 dichlor should get you a FC of 9-10. If you had some present it would be even higher than that, obviously. So to have 4 ppm present 48 hrs later isn't to hard to fathom. I think your ok.
I have been shocking exclusively with mps lately but when I do shock with dichlor I'm usually in the next day.
« Last Edit: January 06, 2007, 08:36:12 pm by WHY_NOT »
In Canada eh
« Reply #4 on: January 06, 2007, 08:35:58 pm »
MLG
        I normally only shock with dichlor once a month to kind of super sanitize the tub.  Weekly I shock with MPS because you can use the tub in about 15 mins
Bullfrog 451
Chad
« Reply #5 on: January 06, 2007, 08:47:16 pm »
MLG, Do you follow the Vermonter's Method for dichlor dosing? (adding dichlor post soak each day) If so I have a little regimen that you can follow and should help simplify things.
For a 225 gallon Jettsetter with a low bather load(just like me :D)-
1 tsp of dichlor post soak should be enough to get a 3ppm acc. to my calculations.
Once a week add 2 ozs of Renew (LT's mps) as a shock, substituting one week a month with 1 TBS of dichlor.
I hope this helps.
« Last Edit: January 06, 2007, 08:58:40 pm by WHY_NOT »
MostlyLurkingGal
« Reply #6 on: January 06, 2007, 08:47:20 pm »
I hate shocking....sigh
MostlyLurkingGal
« Reply #7 on: January 06, 2007, 08:48:28 pm »
I hope this helps.
Yes, that's what I do...all is fine until I shock
neocacher
« Reply #8 on: January 06, 2007, 11:10:04 pm »
Could someone send me the link for the Vermonter regimen?
Thanks.
Neo
Gomboman
  • My Pride and Joy
« Reply #9 on: January 06, 2007, 11:53:01 pm »
Thanks.
Neo
Neo, it's under the FAQ section.
http://www.rhtubs.com/cgi-bin/bbs/config.pl
« Reply #10 on: January 07, 2007, 04:59:20 am »
Never test your PH or TA after a shock. Ignore those readings and do your balance adjustments and read your test results before or after your Chlorine level has gone below 2 PPM
MostlyLurkingGal
« Reply #11 on: January 07, 2007, 09:40:20 am »
I guess my question is, should my Chlorine readings still be so high 48 hours after I shock? If not, should I be doing less than the recommended 1 tbsp or will that defeat the purpose of a shock.
Chad
« Reply #12 on: January 07, 2007, 09:52:23 am »
How much FC was present before you shocked and what was the CC? The shock dose is completely relative to how much CC is present. So if one TBS brings your water from a 0 to a 9-10ppm, that would be the correct dose only if your CC was 1 or less. Whatever the CC is you need to take that number and x it by 10 and then add enough dichlor to get to that specific ppm. You'd rather add a little more than not enough as adding less than needed will actually cause more harm than good. This is why I reccommended just adding 2 ozs of mps a week and be done with it. :)
neocacher
« Reply #13 on: January 08, 2007, 09:33:01 am »
I could not find this section on the web page. I am looking for the Vermonter method. I still need help finding this link. Thanks.
Neo
windsurfdog
« Reply #14 on: January 08, 2007, 09:53:54 am »
neo,
What is the "Dichlor Dosing - Vermonter Style" ?
mlg,
If you are experiencing between 2-3 ppm CC, then your tub should smell to high heaven with the "chlorine" smell.  I've never been able to see mine above 1 ppm and the recommended (Taylor book) shock level is .2-.5 ppm.  If you want to shock with dichlor and you indeed feel like the 2-3 ppm CC is correct, you would have to raise your FC to 20-30 ppm...and that's a huge amount!  I really don't think your CC is at the level you think you are seeing but I have no explanation as to your predicament.  I would recommend shocking with MPS in this case.
