Author Topic: Dichlor dose isn't holding FC as long any more  (Read 4616 times)
Chad
  • 2006 Jacuzzi J-345
Re: Dichlor dose isn't holding FC as long any more
« Reply #15 on: December 31, 2006, 09:27:22 pm »
Why Not,
The formula for when to change your water from the taylor book is
# of days = 1/3 volume (gal) by the Max # of daily bathers
example from the book follows as:
1,200 gallon spa commerical spa is is used over the weekend by 200 people then you should change the water at 2 days
I have the taylor test kit k-2005 and it is on page 39
Hope this helps
CapMorgan
Thanks Cap Morgan. I found it. :) I must have thumbed right over it. It's the same as the one I just posted. I guess it must be the standard formula then for changing hot tub water.
Do you measure for TDS or can you just tell when it's time?
CapMorgan
« Reply #16 on: December 31, 2006, 09:31:00 pm »
Yes i do measure for TDS, i think they work ok i got my from DOC site.
CapMorgan
Chad
« Reply #17 on: December 31, 2006, 09:34:20 pm »
CapMorgan
Thanks again CapMorgan. I'll place an order.
anne
« Reply #18 on: January 01, 2007, 12:16:20 pm »
A couple more thoughts for you:  If I remember correctly, chlorine is 50% hypochlorous acid at pH 7.5 and 75% at 7.0, (roughly 5%/pt of pH) so the pH rise could account for 15% decrease in sanitizer efficiency.
Reese, I was sort of thinking the same thing; certainly an increase in pH will render the chlorine present less effective, but he said that the measured FC was lower than expected......that doesn't make sense, does it? a pH increase, within reason, should not change the FC level on a taylor test kit, I dont think.....?
Dance like nobody's watching
Chad
« Reply #19 on: January 01, 2007, 02:52:42 pm »
Yes that it is correct. It's taking more dichlor to get the same FC reading lately.
For instance I added 1 TBS yesterday at 2:00 a.m. and 20 minutes later I had a FC of 6. Last month it would have been more like 8-10. Also, today at 7:00 a.m.(29 hrs. later) I tested for FC and none was present. Last month I was having some present 48 hrs later with that same post soak ppm. :-?
Chad
« Reply #20 on: January 01, 2007, 03:32:20 pm »
Thanks for all the help guys/girls. CapMorgan's links helped me find the culprit to my dichlor problems. I'm pretty sure it's just due to my high CYA level.
« Last Edit: January 01, 2007, 03:33:05 pm by WHY_NOT »
Tyheethan
  • Jacuzzi J-355
« Reply #21 on: January 05, 2007, 04:20:51 pm »
So Why Not--how did this whole thing turn out?    Also, as a newbie, I don't know what CYA level is?  I think TDS is Total Dissolved Solids but not sure.  Also,  if you had high CYA or TDS, how would you/did you treat it?
Tyhee
Chad
« Reply #22 on: January 05, 2007, 04:44:11 pm »
Tyhee
Thanks for asking.  I've decided not to dump yet as I'm waiting for my TDS strips to arrive. That will be the deciding factor. I didn't want to dump just b/c my dichlor demand increased due to the high CYA. Afterall my water still clears up really fast after I turn the jets off and it still feels great.
Here is a link about CYA http://www.whatsthebest-hottub.com/cgi-bin/yabb/YaBB.pl?num=1167434259/30#30 Tony and Capmorgan helped me alot.
To answer your question about treating high CYA or TDS, the only way is to do a full or partial water change. Once they're present, they're there to stay.
