Author Topic: How can I get rid of this bug?  (Read 3234 times)
vlady
  • 05 Sundance Cameo
« on: January 04, 2007, 12:37:06 pm »
A moth has flown up in the control panel and died.  How can I get it out of there?
Re: How can I get rid of this bug?
« Reply #1 on: January 04, 2007, 12:40:01 pm »
looks like a software bug. Better call tech support.
Course. they'll tell you it's a feature.
RobRoy
« Reply #2 on: January 04, 2007, 12:56:31 pm »
How did that get in there. Removing the top side and shaking it out might be the only way. Its not that difficult to remove, and silicone it back into place.Labor wise maybe 1/2 hour.
« Reply #3 on: January 04, 2007, 01:48:53 pm »
I've had it happen before...not a moth, but a smaller bug.  It disappeared on its own.
East_TX_Spa
    • I Love My Spa
« Reply #4 on: January 04, 2007, 01:52:29 pm »
I really want to know what the little eye on the bottom left is for.
Terminator (the Curious)
« Last Edit: January 04, 2007, 01:52:50 pm by East_TX_Spa »
RUBADUBDUB
« Reply #5 on: January 04, 2007, 02:00:39 pm »
Term, Thats so you can INVERT the display screen. It allows people who can't read upside down to see what the temperature in the tub is when they are in it! ;)
East_TX_Spa
    • I Love My Spa
« Reply #6 on: January 04, 2007, 02:16:24 pm »
Cool!  Turn the display upside down, the moth will fall out, problem solved.
Terminator
vlady
  • 05 Sundance Cameo
« Reply #7 on: January 04, 2007, 02:19:41 pm »
No, no, no - that isn't what the button does.  That is the "beam me up" button.
RUBADUBDUB
« Reply #8 on: January 04, 2007, 02:36:38 pm »
Terminator
I'm sorry I replied..... ;) ;D ;D
Zep
  • Cal Spas SQ92 Dallas-Texas
« Reply #9 on: January 04, 2007, 02:51:54 pm »
re: Thats so you can INVERT the display screen
That is an excellent idea!
East_TX_Spa
    • I Love My Spa
« Reply #10 on: January 04, 2007, 03:02:04 pm »
The Tiger River Spas display does the same thing.  I'm trying to catch me a moth in my Caspian to see if it will work.  So far, I ain't caught nothing.
Term
« Reply #11 on: January 04, 2007, 03:04:45 pm »
I was thinking it was for the ejection seat.
Zep
« Reply #12 on: January 04, 2007, 03:17:58 pm »
re:  I'm trying to catch me a moth in my Caspian to see if it will work.
Terminator ...take all them moth balls out from inside your spa shell...
you'll catch one!
East_TX_Spa
    • I Love My Spa
« Reply #13 on: January 04, 2007, 03:22:35 pm »
I always wondered how difficult it would be to get a vasectomy if you were a moth.
Terminator
tanstaafl2
« Reply #14 on: January 04, 2007, 06:45:48 pm »
If it got in there has to be a hole somewhere. If you can see the backside of the panel from inside the tub when you remove the outside siding and can find anything that might be the access point the bug went in through perhaps you can put a vacuum on the bottom and suck the little bugger out of there? Might need to use a bit of rubber like an "O" ring to create enough vacuum. But if the surface isn't very flat probably won't work. Can't recall off the top of my head what the bottom side of the control panel looks like and it is probably different from yours even if I could.
Assuming you can find a hole in the first place!
