Author Topic: Too much Bromine  (Read 46174 times)
richopian
Too much Bromine
« on: December 18, 2006, 02:53:39 pm »
Hi all,
I think I put a little too much shock, bromine in etc when I first filled my tub yesterday.
The Bromine level was a bit too high, and I was wondering if there is a quick way of bringing the level down. i removed the Bromine floater last night and I'll check it after work today. Maybe I just have to wait a day or 2.
cheers
Rich
Too much Bromine
Re: Too much Bromine
« Reply #1 on: December 18, 2006, 03:05:30 pm »
  Pull the floater for a day.  Re check.
I think using the spa would also help knock it down, but not sure if you'd want to do that if the level is high.
« Last Edit: December 18, 2006, 03:06:31 pm by Brewman »
Tatooed_Lady
« Reply #2 on: December 18, 2006, 03:08:30 pm »
hmm...throw in some dirty laundry, put the bromine to work.  ;)
Okay, not so much? How about a partial drain/refill? What is "too high" for the bromine reading, btw?
RIP C-Rod
LtDan
  • Jacuzzi J345
« Reply #3 on: December 18, 2006, 03:08:50 pm »
Give it a day or so. What I discovered is to make very small adjustments with the bromine. Cranking the floater closed too much to compensate for a high reading has resulted (for me) in not enough bromine necessitating a water change. There is some fluctuation when using a floater, once you are dialed in you'll be all set.
Bonibelle
  • '05 Marquis Epic
« Reply #4 on: December 18, 2006, 03:09:05 pm »
Rich, I remember worrying so much over the bromine levels too. I was afraid to go in if the bromine was real high.. Several on here told me not to worry...(Dr. Spa and Bosco to mention just two) and just jump in. We did, even when the test strip was "glowing".The bromine level will actually decrease just by using the tub..Alternately you can try to run the tub with the cover off for a little while. I really didn't have much luck doing that... If you are concerned that the bromine might bother your skin, just shower after you soak. Just watch that your bromine level doesn't take a fast dive since you removed the floater.
Good luck  ;)
« Last Edit: December 18, 2006, 03:09:58 pm by Bonibelle »
bosco0633
  • Look into my eyes
« Reply #5 on: December 18, 2006, 10:16:29 pm »
Bon, you are making me sound like I know what im talking about.  Word of caution, I have been glowing green for the past year.  Is this normal.
I agree, jump in and enjoy it, your oils and junk will drop the bromine level quickly
« Last Edit: December 18, 2006, 10:20:15 pm by bosco0633 »
Bama
« Reply #6 on: December 18, 2006, 10:51:34 pm »
Bosco,
As per your photo...you have this strange twiching, I think you've had one too many bromine soaks!   ;D ;D
hot tub Frank
  • tiger river bengal
« Reply #7 on: December 26, 2006, 02:23:29 pm »
as we all know cops end up in all kinds of dangerous situation.
what could high bromine do to him??????
« Last Edit: December 26, 2006, 02:23:51 pm by hot_tub_Frank »
« Reply #8 on: December 27, 2006, 02:10:42 pm »
To reduce the bromine level,
add people.
 8-)
hot tub Frank
« Reply #9 on: December 27, 2006, 10:35:08 pm »
how about a lot of romance in the tub :-[ :-[ :-[ :-[ :-[
Tatooed_Lady
« Reply #10 on: December 28, 2006, 11:16:05 am »
add people.
 8-)
I love the "KISS" theory....crude, but effective.  :D
RIP C-Rod
