Author Topic: Posting for a friend  (Read 3631 times)
bosco0633
  • Look into my eyes
« on: December 15, 2006, 12:14:20 pm »
A friend of mine has a calspa.  He had a party in the summer and after that they stopped using the tub for the rest of the summer.  For the past month he has been running into an issue.
He drained and filled tub and ran jets and noticed a chicken noodle soup style object floating in the tub.  It is white/yellow in color about 2 to 4 inches long.  The tub is saturated in them.  They almost look like toilet paper up close.  I just saw it today and it is crazy.  I thought white mold right away, but he does not think so.
Has anyone ever heard of this.  He has drained and refilled, added chemicals like crazy and no success.  He has drained several times and every time that he turns on the jets, he gets more of this.  There is thousands of strands of this floating in the water.  Any help would be greatly appreciated, ie. identifying the problem, and possible solutions.
Ehizzle
  • "We're not here to talk nonsense to Bob Lablaw"
Re: Posting for a friend
« Reply #1 on: December 15, 2006, 12:25:47 pm »
Sounds like water mold to me too. Is it sticky? You have to use like at least a cup of chlorine and run the jets for a long time, then redrain. Sometime if its really bad it takes 2 or 3 times. Nasty stuff. There are also some products for clearing the plumbing of the spa. One is called spa system flush. I dont know if it would help or not.
« Reply #2 on: December 15, 2006, 12:51:25 pm »
Sounds gross.
Don't forget about cleaning/chanigng/burning the filters
and behind any pillows, and what not.
 :P
« Last Edit: December 15, 2006, 12:51:36 pm by drewstar »
Ehizzle
« Reply #3 on: December 15, 2006, 01:11:49 pm »
Yeah it might be easier just to set the whole spa on fire.  :D
« Reply #4 on: December 15, 2006, 01:31:30 pm »
I have seen this before and it sounds like a string algae or biofilm. The only thing to get rid of this is to super chlorinate, ged rid of the filter and anything else that was in the water during that time, drain, wipe down with a bleach solution (50/50), refill and super chlorinate again.
Here's one suggestion: http://www.spa-essentials.com/HTML/Trouble_Bacteria.html
Treat it like pseudomonas.
Check this link out and see if it helps: http://www.rhtubs.com/cgi-bin/bbs/config1.pl?noframes;read=33649
Good luck!
« Last Edit: December 15, 2006, 01:32:15 pm by Steve »
hot tub Frank
  • tiger river bengal
« Reply #5 on: December 15, 2006, 02:27:19 pm »
yuck
Rayman
« Reply #6 on: December 15, 2006, 02:53:15 pm »
Sorry about his luck, I can't help you but i thought you would like to know that I did puke after reading it.
RobRoy
« Reply #7 on: December 15, 2006, 03:04:22 pm »
Ewwww, it sounds like something you may find on the menue at the Texas State Fair.
« Reply #8 on: December 15, 2006, 03:19:03 pm »
It does sound like white water mold.  The decontamination methods mentioned should work.  Until he kills it all, he won't get rid of it.
Not fun.
anne
« Reply #9 on: December 15, 2006, 03:58:54 pm »
Sounds like a job for Swirl Away?
Dance like nobody's watching
Reese
« Reply #10 on: December 15, 2006, 04:05:21 pm »
I think you have to make sure everything is dead first.  rhtubs.com has a procedure for decontaminating a spa in the FAQ or one of the guides.
RUBADUBDUB
« Reply #11 on: December 15, 2006, 04:08:29 pm »
White mold, or Silly string....you choose... :P
I too vomitted alittle in my mouth
**this is just my opinion**
« Reply #12 on: December 15, 2006, 05:14:08 pm »
Swirl Away is a great product Anne but not for this application. It's great at removing calcium and mineral deposits from the plumbing but what he needs is a sanitizer (chlorine/bleach) to kill this algae. Swirl Away has no "killing" aspect to it.
Ehizzle
« Reply #13 on: December 15, 2006, 05:43:04 pm »
I think a good solution of 40 part commet to 18 parts windex otta take care of it. ;)
anne
« Reply #14 on: December 15, 2006, 05:45:46 pm »
That is good to know. I was not sure what Swirl Away "swirled" away.....now I do. I thought that it helped to detach organic debris from pipelines.
