Author Topic: filling new tub with warm water?  (Read 15518 times)
still sore
« on: December 10, 2006, 10:58:10 pm »
Probably a little late to be asking this. My D1 california is scheduled to be delivered first thing tomorrow morning. Obviously, I'd like to be soaking ASAP. I thought I read somewhere the tub should be filled only with cold water. Reviewing the owners manual it is not specified. So, can I fill the tub with a mix of warm and cold tap water? I know my water heater won't keep it hot for to long but a little has to be better than nothing. I live in upstate NY and don't expect it to get much above freezing tomorrow. Any thoughts?
Re: filling new tub with warm water?
« Reply #1 on: December 10, 2006, 11:43:16 pm »
A mix should be ok.  Start with the cold, maybe half the tub.
pg_rider
  • I've been Optima-ized
« Reply #2 on: December 10, 2006, 11:49:45 pm »
I thought about that too but was too lazy to hook onto my hot water.  As it turns out, right from the tap the tub measured 61 degrees, and was hot at 102 degrees about nine hours later ( was probably hot earlier than that, but that's when I got home from work).  If you fill it in the morning it should be hot by afternoon...
Paul G.
2006 Sundance Optima
macejh
  • 2005 Gulf Coast Rotunda
« Reply #3 on: December 10, 2006, 11:58:04 pm »
I thought about that as well but most water heaters are behind the water softener.  If you have a softener, Im told you should bypass the softener (water heater water) as the hot tub requires some of the minerals naturally occuring in water.
tileman
« Reply #4 on: December 11, 2006, 12:49:38 am »
Still sore, congratulations on the new spa!
Filling it with warm water from the tap is clever and will not cause any problems. I would think it might save you an hour or so. My spa took aproximately 6 hrs to heat from 64 to 100. Hope everything goes well and keep us posted. :)
« Last Edit: December 11, 2006, 01:05:53 am by tileman »
tileman
« Reply #5 on: December 11, 2006, 12:51:24 am »
You are correct sir. 8-)
« Reply #6 on: December 11, 2006, 05:49:05 am »
What, a 50 gallon hot water heater in 300-400 gallons of water. It may raise it a degree or two but not much. And you would have to wait for quit a while to get another batch, might as well keep filling and let the tub heater do it.
« Reply #7 on: December 11, 2006, 07:36:09 am »
Tman122 nailed it.
Tatooed_Lady
« Reply #8 on: December 11, 2006, 07:43:24 am »
the part that sucks, however, is WAITING!!!!!!!! Our water came out at about 51 degrees, and that was BEFORE it got cold!
RIP C-Rod
Rayman
« Reply #9 on: December 11, 2006, 08:29:35 am »
For the same reason you are not supposed to use hot water to fill you Kettle or Coffee maker, there are nasties in the hot water tank that can get in your tub.  This is what I have been told, I have been wrong before.
Tileman your always right and you say it's ok so I guess I must be wrong then
Ray
Ruby
  • Marquis Epic
« Reply #10 on: December 11, 2006, 08:31:47 am »
I think this topic came up a couple years ago when I first joined.  If I remember correctly, there was a concern about the sediment  from a water heater when it is drained all the way.  I may be wrong though.
Minnesota Consumer
Been soaking since 7/2004
Rayman
« Reply #11 on: December 11, 2006, 08:36:58 am »
dkersten
« Reply #12 on: December 11, 2006, 10:40:21 am »
I thought I would do this when I got my tub as well.  I asked the dealer, and his response was NO.  His reasoning was because adding hot water to the tub will cause a very sudden increase in temperature to the shell, which could potentially weaken it by rapidly expanding.
The only thing I see wrong with this is that putting cold water in a tub that has beed draining in the sun would be just as damaging, so what is the difference?
BTW, 50 gallons of water at 140 degrees to 300 gallons of water at 50-60 degrees is going to make a pretty large impact on starting temperature.  You would see about a 10-12 degree increase.  Furthermore, my shower kicks out about 4 gallons per minute, and I can take a shower at 104 degrees for well over 45 minutes and still have hot water.  That means that if I filled the tub at 4 gallons per minute, I could fill over half at full temp water, probably more.
Now, the flip side is that first off, I would have to fill from the kitchen sink, which is maybe 3 gallons per minute tops.  If I did pure hot water from tap and a cold water from outside faucet, it might work, but I would be worried about having 2 hoses almost 100 degrees apart hitting different parts of the tub at the same time.
Second, my tub has a 6000 watt heater, and from the 50ish degree water from my tap, I am up to 103 in 5-6 hours.  The first time I filled the tub, it was full at 5pm and I soaked at 10:00, the tub was around 100 degrees.  The second time, I got finished filling at about 6 pm and at 11 it was around 100, and it was 40 degrees outside.  There really was no need to worry about adding hot water.
Personally I wouldnt put hot water in.. if anything just because of the unlikely potential to cause damage to the shell or fittings.. sudden expansion or contraction of a PVC joint where it meets the shell may not break the seal, but it cant be good.  Also, keep in mind that the whole hot tubbing experience is for relaxing.. you cant rush a good relaxation session.  If you get the tub installed by noon, you will be able to soak that night most likely.
Tatooed_Lady
« Reply #13 on: December 11, 2006, 10:41:04 am »
Ray
Uh-oh....I'm not supposed to use hot tap water to fill the coffee maker????  :o
RIP C-Rod
« Reply #14 on: December 11, 2006, 11:01:09 am »
Using the drain valve on the water heater isn't a good idea for anyting excpet draining the tank- the sediment on the bottom of the tank will follow the water right out.
 I for sure wouln't use that method to fill a spa.
There shouldn't be any "nasties" in your water heater tank- assuming by nasties you mean bacteria.  The heat in the tank should keep them from forming.
I don't think drinking water from your water heater in small amounts would be necessarily bad, but in our house all the water from the water heater is soft, and I don't like drinking softened water or using it in food.  I have the cold water tap on our kitchen set to deliver unsoftened water, so I use that for cooking and drinking.
The water from our water heater is used for laundry and bathing, etc...
 Why use hot water for your coffee maker when the coffee maker heats the water?
Just curious.
« Last Edit: December 11, 2006, 11:03:06 am by Brewman »
