Author Topic: Spa Frog  (Read 7316 times)
Davidny
Re: Spa Frog
« Reply #15 on: December 07, 2006, 05:15:21 pm »
You'll want to shock whether you are using chlorine or bromine.  It is possible to shock with a high dose of chlorine, but I reccomend using potassium monopersulfate which is a non-chlorine oxidizer.  I think that is what most of the people on the forum use.
On a spa board I read someone recommended using potassium monopersulfate after soaking and a Cl shock once a week. Is it necessary to use Cl at all or can I get away with potassium monopersulfate+ozone+spafrog?
Re: Spa Frog
tileman
Re: Spa Frog
« Reply #16 on: December 07, 2006, 06:33:34 pm »
Yes, you need some sort of sanitizer, either chlorine or bromine. MPS has no sanitizing ability. It's strictly an oxidizer.
NE-Phil
  • Marquis Reward '05
Re: Spa Frog
« Reply #17 on: December 07, 2006, 09:54:31 pm »
Commonly known as MPS, the "non-chlorine" shock. It's made by DuPont. Oxy-Spa is one brand name you'll see. It has the distinction of being 100% MPS - no fillers. That means you'll use less to get the same results.
Phil
Re: Spa Frog
