Author Topic: 02 grandee need help found the problem  (Read 5687 times)
jfish63
  • 2002 HS Grandeee
« on: November 20, 2006, 08:39:51 am »
My bargain tub has a couple of issues. The jet pressure is low and it surges. It seems like I have a large air lock. I tried clearing it by setting the valves to the 3 o' clock pos and running the jets but that didn't clear it. Also how can you tell if the ozonator is working? I ran vinegar through it but I don't have an indication light on the control panel. I could really use some help on the jet situation.
« Last Edit: November 20, 2006, 06:02:32 pm by jfish63 »
Re: 02 grandee need help
« Reply #1 on: November 20, 2006, 09:54:05 am »
Describe your filling procedure.  Do you have an owner's manual?
shabba34
« Reply #2 on: November 20, 2006, 10:27:21 am »
Couple things to check:
1) Make sure water level is high enough.  To the base of the pillows.
2) Make sure the floating wier door is not jammed in the raised position.
3) Make sure the filters are clean.  If they are calcified, not enough water is getting to the pumps.
4) It's rare to have an air lock on your main pumps, more common on the circ pump.  Usually it is something very simple such as 1-3, but on occassion it could be voltage drop causing the surging...  Good luck.
jfish63
  • 2002 HS Grandeee
« Reply #3 on: November 20, 2006, 11:03:57 am »
The water level is the center of the tile.
Floating door not jammed
Filters are brand new
I fill with the hose in the gray filter tube
I have the manual
I followed the manual for removing the air lock by setting the diverters to 3 o'clock and running the pums with air valves open. With the pumps on I can hear what I think would be a air lock type situation (a loud pump and surge). The moto massage does not even move.
jfish63
  • 2002 HS Grandeee
« Reply #4 on: November 20, 2006, 05:57:32 pm »
Ok I think I found the problem. Now I just need to know what it is. In the equipment compartment on the right side up high there is a black
"T". It has two 1 inch clear pvc pipes clamped to it. On the far end of the "T" there is a 3/8" tube with a diaphram on it and there is a slide in clip holding it together. The clamp and the bottom of the T on that end are broken. If I hold the pieces together the surging stops almost immediately. I don't think the moto jets move yet though. Can someone tell me what this part is?
« Last Edit: November 21, 2006, 10:25:59 am by jfish63 »
jfish63
  • 2002 HS Grandeee
Re: 02 grandee need help found the problem
« Reply #5 on: November 21, 2006, 11:51:19 am »
The one thing I can say about Hot Spring tubs, The dealers are knowledgable and spare parts are so far in stock. I just talked to the local dealer he has the part in stock. It is a newer version and is called a Hartford loop. I'll pick it up on the way home. Now I just have to get the moto massage to work. Gotta love soaking ;D
SpaMorph
« Reply #6 on: November 21, 2006, 12:08:47 pm »
One thing I've noticed on many of the used/older HS tubs is that the moto massage jets frequently do not work.
jfish63
  • 2002 HS Grandeee
« Reply #7 on: November 21, 2006, 12:58:43 pm »
Is there any way to fix the moto other than replacing the snake part or wharever they call it?
« Reply #8 on: November 21, 2006, 01:47:57 pm »
Are you sure you have the diverters and air valves turned so that you have water and air going through it? If that's the case and it really is in need of a change it's a 5 minute job that you can do without need of service so the dealer can help explain when you get the part.
jfish63
  • 2002 HS Grandeee
« Reply #9 on: November 21, 2006, 01:52:48 pm »
The valve is in the 3 o'clock position and the air is on. If I can do it full of water I'll give it a shot.
jfish63
  • 2002 HS Grandeee
« Reply #10 on: November 21, 2006, 05:37:33 pm »
ok picked up the part and installed it. What a difference. This is an awesome tub. The jets were really weak and I was a little disappointed. But since I put in the part they are right on the money. It even fixed the moto massage jets. ;D  way cool
galen
  • Maxxus
« Reply #11 on: November 21, 2006, 05:45:20 pm »
Good to here you got it fixed Fish. Happy tubbing. 8-)
« Reply #12 on: November 22, 2006, 12:03:30 am »
It sounds like your pump was sucking air previously. Glad to hear it was an easy fix. you are now a qualified spa technician. Send me $20 and I'll send you as certificate.
hottub.pool_boy
« Reply #13 on: November 22, 2006, 09:57:42 pm »
you need to replace the black t thing with what's called a "hartford loop." It's a Htospring retro kit for that year spa. It will for sure fix your surging jet issue. We sell em' and will ship one if you can't get it.
Sorry, got excited and didn't read all the posts.
« Last Edit: November 22, 2006, 09:59:54 pm by hottub.pool_boy »
