Author Topic: Water change in under 1.5 hours  (Read 2120 times)
bosco0633
  • Look into my eyes
« on: November 14, 2006, 03:10:08 pm »
This am I placed fresh start in let it run for 1 hour.
Went out at 9am and hooked up hose to drain and also I used an item the dealer loaned me.  It is a quick drainer.  It has a long 3 foot 1" tube on it with a hose and it drained fast.  I cleaned out the tub, treated the head rests, blew out the lines sprayed the tub with anti bacterial and I was filling before 10am.  Tub filled, bromine reserve added and new filter placed in.  Added a zorby sponge and I am good to go before 11am.
water was 53at 11am and now it is sitting at 84at 3pm.  4 hours 31 degrees, should be good to go by tonight for a soak at 104.  Cant wait, love the new water.
Oh by the way, refresh worked amazing, The water looked so bad after I used this.  It got dirty but I took the side panel off and noticed that the clear lines looks great.
Garyjr
  • Let's SunDance!!
Re: Water change in under 1.5 hours
« Reply #1 on: November 14, 2006, 07:24:16 pm »
bosco,
How did you blow the lines out?
Thanks,
Jr
kervis
  • runnergirl
« Reply #2 on: November 14, 2006, 10:43:22 pm »
Wahoo!!  You rock.  :)
2005 HS Vanguard
bosco0633
  • Look into my eyes
« Reply #3 on: November 15, 2006, 08:05:12 am »
I hooked up my blower to the filter chamber and it pushed water through lines out jets.  Then just to be sure, I switched the pump from blow to suck, (easy terminator) and minimal water came out.  Worked for me.
I went in the tub at 6:45pm with my son.  So drain and refill 9hrs 45min.  I can live with that.
