Author Topic: Trixie's bubbles...  (Read 3412 times)
Bama
Trixie's bubbles...
« on: November 08, 2006, 02:24:54 pm »
That crazy  ;DTrixie  ;Dmust have dumped a whole bottle of bubble bath in the spa at one of her wild parties. :-*
So, now I'm left with random under garments and bubbles...lots of bubbles!  What's a girlfriend to do about all these bubbles??? :o
Is there a de-bubbler or anti-bubbler on the market?
« Last Edit: November 08, 2006, 02:27:44 pm by Bama »
Trixie's bubbles...
Re: Trixie's bubbles...
« Reply #1 on: November 08, 2006, 02:40:38 pm »
Scoop out as much foam as you can, then add the smallest amount of defoamer that takes the rest out.  Then keep the suds outa spa- though fun, it can be a pita to fix.
 Or if your water is nearing that point, just dump and refill.
When you go to the spa shoppe to get this stuff you have to ask for it using the correct terminology, which is actually un-bubbler.
« Reply #2 on: November 08, 2006, 05:22:27 pm »
After scooping, hit it with MPS.
hot tub Frank
  • tiger river bengal
« Reply #3 on: November 08, 2006, 08:29:41 pm »
It is about time that trixi started up a new topic.
lagator43
  • My wings are a shield of steel.
« Reply #4 on: November 08, 2006, 08:34:24 pm »
unddddderrrr garmmmments :o  I wish I was invited to parties like that.  Any stories you wish to share? ;)
« Last Edit: November 08, 2006, 08:36:15 pm by lagator43 »
Gomboman
  • My Pride and Joy
« Reply #5 on: November 08, 2006, 11:18:45 pm »
« Last Edit: November 08, 2006, 11:43:32 pm by Gomboman »
Bama
« Reply #6 on: November 09, 2006, 01:36:42 pm »
Trixie, how about a picture?
http://www.whatsthebest-hottub.com/cgi-bin/yabb/YaBB.pl?num=1147381254/0
I tried to post photos of the beautiful view from the spa, however I couldn't get them here.  I'll try again.
Bama
« Reply #7 on: November 09, 2006, 01:41:17 pm »
Trixie had a huge party after the voting polls closed.  I think she owed a few customers  friends a few favors!   ;)
Bama
« Reply #8 on: November 09, 2006, 01:46:08 pm »
Do the bubbles actually cause damage to the spa?
'Cuz, adding a bottle or two of bubble bath to the spa is fun.  How about if it's done the day before dumping the water?  Any harm in that?
I found a bottle of ANTI-FOAM, however it says that you can use it only 4 times between dumping water.  Now, I'm wondering if this stuff is unhealthy, or if it throws off the test results?
« Last Edit: November 09, 2006, 01:51:23 pm by Bama »
Bama
« Reply #9 on: November 09, 2006, 01:57:43 pm »
Hi Hot Tub Frank...
it's nice to know someone cares!   :)
By your name, I can tell you are enthusiastic about your hot tub!  Me too!!!
I use it three or more times per day!  Actually, I was a Flight Attendant and got hurt when an emergency slide and I fought it out!!!  The slide won!!!  ;D
So, far the jets are working wonders for my achy back.
geekd
  • 2006 HS Grandee
« Reply #10 on: November 09, 2006, 05:26:35 pm »
I got some "Spa Foam Down", and put it in a spray bottle I got at Home Depot for $3.  I diluted it to half strength, and I spray it directly on the foam.
This way, it goes right where I need it, and I use a lot less.
I get some foam after each monthly filter cleaning, because no matter how much I rinse, I can't seem to get all the soap out of the filter cartridges.
Brookenstein
« Reply #11 on: November 09, 2006, 06:02:45 pm »
I'm so not following this...
If you are purposefully adding a bubble making product to the spa, such as bubble bath, I would assume that is because you want bubbles.  Why then would you be wanting to use a defoaming product?  Wouldn't that, I dunno, take away the bubbles you just added?  Is it you just want bubbles sometime, but not all the time?  How bout you wash your swim suit and wear that in the tub once, (then quickly take it off if you prepare to go without)... that should give you some bubbles for a day or two.
I guess I just don't get it.
I do remember a post on here a long time ago by a regular in the business who said he did let his kids have a bubble bath on occasion before water changes.  So... I wouldn't think its that horrible on the spa, but i think rinsing the filters good would be a PITA.
hot tub Frank
« Reply #12 on: November 09, 2006, 06:04:07 pm »
trixi I wish i had the time to soake 2 or 3 times a day.
I still have to work for living.
hot tub Frank
« Reply #13 on: November 09, 2006, 06:05:42 pm »
trixi must be still on her wild side.
is that what the slides do ?
Bama
« Reply #14 on: November 10, 2006, 01:14:19 pm »
Actually, the slides on the airplane are for emergency evacuation.  That's what I was doing...we had an emergency and I deployed my slide, it mal-functioned and got hurt.
I have had some wild times in the aircraft, but that day wasn't one of them.
