Author Topic: FLO Error  (Read 2787 times)
lskarp
  • There is no patch for stupid
FLO Error
« on: November 06, 2006, 07:53:54 pm »
OK, first problem!!!
I went to crank up the heat when I got home from work and I was greeted to a FLO display on my Vita Nuage.  The book says it is a flow error.  I pulled and rinsed both filters which appeared clean as I dumped the water 2 weeks ago and did a dishwather run with them after using the Leisure Time spray cleaner.
No luck, so I left the filter off and tried again, and still had a FLO error.  The jet pumps work fine, but teh circ which I have on 24X7 does not seem to be on and flowing.
I will call the dealer tomorrow, but I woudl like to go in tonight!!
Any ideas??
FLO Error
Re: FLO Error
« Reply #1 on: November 06, 2006, 08:05:16 pm »
Turn off the tub, wait about 5 minutes and turn it back on ... maybe the electronics got confused.
lskarp
Re: FLO Error
« Reply #2 on: November 06, 2006, 08:14:58 pm »
Did that 2X.  Now I am in teh wait 30 mins mode, then I may try a factory reset.
There is always teh dealer, but then we are looking at a coupld of days b4 I get to go back!!
George
Re: FLO Error
« Reply #3 on: November 06, 2006, 08:23:05 pm »
I have heard some have reported getting FLO problems with an Air Lock.
lskarp
Re: FLO Error
« Reply #4 on: November 06, 2006, 09:39:48 pm »
I jammed the garden hose in the pipe with a towel wrapped around it and tiny ozone looking bubbles came out of teh filter outlet port.  I am thinking it is a terminal thing for teh Circ pump or the underlying electrics.  I am under warranty, so they will look at it and repair.
Any more ideas, let me know.
THX all!!
Re: FLO Error
« Reply #5 on: November 07, 2006, 07:47:06 am »
You did the right thing.
You've eliminated the likely culprits, filter and airlock, and now it's probably down to a mechanical issue.  On my spa it was a bad circ. pump- falied about a year ago.
 Could be anything that is causing the FLO switch to trip.
« Last Edit: November 07, 2006, 07:51:14 am by Brewman »
lskarp
Re: FLO Error
« Reply #6 on: November 08, 2006, 06:21:39 am »
I am figuring as much.  I called my dealer and he is geting a guy out.  They usually take 1 - 2 days to actually call and show.  I figure that we are looking at a circ pump connection or mechanical problem.
So far no hassle from the dealer.
Total bummer though as I am moving 200 people into a new office on Friday, and I can sure use the spa!!!
THX all,
LK
Re: FLO Error
