Author Topic: Question about Swirl Away  (Read 11750 times)
bosco0633
  • Look into my eyes
« on: November 07, 2006, 03:52:58 pm »
I am getting ready to empty my tub for the cold months ahead and was wondering if anyone could help me out.  My tub is almost a year and a half old now.  I have not used swirl away and I dont want to buy it if I dont need it.  My tub has been issue free since i have had it.  Should I use swirl away and if so, what exactly does it do and how do I use it?
Any help would be appreciated.  I hope to drain it this week sometime.
cooltoy2000
  • Go Flames Go!!!
Re: Question about Swirl Away
« Reply #1 on: November 07, 2006, 04:00:45 pm »
From rhtubs:
This product cleans accumulated unseen deposits of oily grime, microorganisms, and other foreign matter from inside the plumbing system.
Swirl Away
HOT TUB AND WHIRLPOOL BATH PIPE CLEANER
Clean What You Don’t See !
DO NOT OPEN AIR CONTROLS WHILE CLEANING!
DIRECTIONS FOR WHIRLPOOL BATHTUB:
Pour 1/2 bottle of Swirl-Away into tub filled with hot water.
Turn pump/timer on for 15 minutes
drain tub and rinse with clean water
repeat this procedure monthly
DIRECTIONS FOR HOT TUBS AND SPAS:
Pour bottle of Swirl-Away into tub filled with hot water before draining.
turn pump on at high speed for one hour
Drain and resume to normal maintenance procedures
Repeat this procedure every 2 - 3 months, or as required.
cooltoy2000
  • Go Flames Go!!!
« Reply #2 on: November 07, 2006, 04:02:31 pm »
Another site:
Removes built up deposits from blocked pipelines and jets, ensuring optimum performance of the spa's or whirlpool's plumbing system. The unique combination of detergents, cleaning agents and emulsifiers in Swirl Away soften deposits and clear pipes of bath and baby oils and other organic wastes.
Swirl Away
Dissolves accumulated bath and body oils and aids in the prevention of build-up in the plumbing lines of your spa. Eliminates blocked or obstructed jets.
Ideal for your spa, hot tub or whirlpool bath.
Directions for hot tubs and spas:
Remove filter cartridge
Pour 250ml of Swirl Away into Spa or Hot tub before draining
Turn pump on at high speed for one hour with air controls closed
Drain and resume normal maintenance programme
Directions for whirlpool bath:
Pour 150ml of Swirl Away into tub filled with hot water
Turn pump/timer on for 10 minutes with air controls closed
Drain tub and rinse with clean water
« Last Edit: November 07, 2006, 04:04:23 pm by cooltoy2000 »
bosco0633
  • Look into my eyes
« Reply #3 on: November 07, 2006, 04:03:46 pm »
ok, so I guess I pour it in the water now, and then drain.  But when I drain the tub, do I have to fill it and drain again and then fill.
If I just drain and fill, will the reminents in the lines cause any issues to my water??
« Reply #4 on: November 07, 2006, 04:08:10 pm »
You certainly don't need it.  Clean, sanitized water filling your spas plumbing doesn't necessitate the need for a plumbing cleaner.  That being said, I like to use Swirl Away every other fill because I like what it does to my jets.  Everything spins and moves a bit better.  I still get a little gunk from the system, but nothing like the first time I used it.  The product is very inexpensive, easy to use, so its just the bother of adding half a bottle and running your pumps for a little bit before draining.
bosco0633
  • Look into my eyes
« Reply #5 on: November 07, 2006, 04:09:38 pm »
tony do you just drain and refill then, or do you drain, refill, drain, refill???
« Reply #6 on: November 07, 2006, 04:10:06 pm »
To answer...no and no.  Just spray a little bit with your hose.
« Reply #7 on: November 07, 2006, 04:12:18 pm »
It definitely wouldn't be worth the effort if you had to fill and drain again.
One other thing...I like Swirl Away better than some of the other cleaners out there (namely Leisure Time jet clean).
« Last Edit: November 07, 2006, 04:44:01 pm by tony »
bosco0633
  • Look into my eyes
« Reply #8 on: November 07, 2006, 04:16:49 pm »
thanks tony!!
I am going to go and buy it right now at my local arctic shop to grab a bottle.
« Reply #9 on: November 07, 2006, 04:22:34 pm »
Spa System Flush isn't too bad either.  Remember to use only half a bottle.
bosco0633
  • Look into my eyes
« Reply #10 on: November 07, 2006, 04:27:07 pm »
I just called my arctic dealer and they have an arctic brand called fresh start.  I am pretty sure that it is just another brand relabeled.  I still think that I will pick it up.  My dealer recommends running the jets on high for 2 hours before I drain.  That seems a little high to me.
« Reply #11 on: November 07, 2006, 04:40:53 pm »
There's several brands out there and you will be amazed at what they will do for you. I have used a few different brands with the same results on my tub and several customers tubs. I have never refilled and drained after but I think it is recomended on a few of them. Just make sure to rinse out your tub thourouly with your garden hose. And for that matter force some water into the upper jets and you will rinse stuff down to your floor jets. Or stick your hose in your filter compartment and let it run through the system and out your lower jets and out your drain.
« Reply #12 on: November 07, 2006, 04:42:24 pm »
Yeah, Swirl Away directions say 15 minutes.  Two hours sounds high.
« Last Edit: November 07, 2006, 04:43:22 pm by tony »
bosco0633
  • Look into my eyes
« Reply #13 on: November 07, 2006, 06:12:35 pm »
I thought that 2 hours was to long as well.  I am going to use it on Friday on my day off.  I just contacted the dealer and he is loaning me the hose that helps drain the tub quickly so I can have a quick turn over.
« Reply #14 on: November 07, 2006, 07:18:29 pm »
I used swirl away at the 1 year mark. I poured in the tub and left overnight. I probably ran the jets for about 1 hour. My thinking was I won't be using the tub anyway so why not.
I did fill, run the pumps again to flush out the system, drain and filled  But I'm anal about certain things and I only plan on doing it yearly ... if I was doing it more than that, I would possibly rethink the dumping of new water.
