Original
Vanguard owners--tri-x cleaning question
Pages: [
Topic: Vanguard owners--tri-x cleaning question (Read 3056 times)
kervis
Full Member
runnergirl
on:
October 30, 2006, 08:08:27 am »
What do you soak your 5 filters in? I had mine soaking overnight in an 18-gallon bin, but only 3 fit in at a time, and I still had to dilute the solution a bit to get it to BARELY cover the 3.
Then, I put the other 2 on top to hold the 3 down under the solution. The directions say 3 hours for sure, but over night is best.
This morning, I rotated the filters and figure that the other 2 will get their 8 hours in as the day goes by.
Is there an easier or better way to do these 5 at once?
I do know that I should store the solution and use it again.
2005 HS Vanguard
on:
tonyp
Full Member
Soaking in a HS Envoy!
Re: Vanguard owners--tri-x cleaning question
Reply #1 on:
October 30, 2006, 08:40:27 am »
No matter what I soaked them in and no matter how much I rinsed, I got suds. So here's my method:
I put my Tri-X filters in the dishwasher. Simply rinse them with a hose. Put them in the dishwasher with a little dishwasher detergent and run. I usually run them through an extra rinse cycle. Then put them back in the spa.
I also run the dishwasher again empty to keep the wife happy.
kervis
Full Member
runnergirl
Reply #2 on:
October 30, 2006, 08:47:07 am »
Do you do this
in place of
the "water change overnight super soak"??
I have done that twice now, using Cascade, with great results--no foaming at all. I have done that in place of the spray-on filter cleaner.
I am thinking that if I just keep using the cascade/dishwasher method, I shouldn't have to do an overnight. What do you think?
2005 HS Vanguard
Webini
Full Member
Reply #3 on:
October 30, 2006, 11:40:48 am »
You guys are using Cascade on your filters?!? Everyone I talked to said not to use dishwasher soap at all.
Brookenstein
Senior Member
Reply #4 on:
October 30, 2006, 03:06:38 pm »
I have one extra filter. I use it to rotate when I do overnight soaks. I only do the overnight soaks (so far) on the one on the circ pump filter though. The others don't seem to need it. They do fine with regular cleaning with hose off and spray on cleaner and dishwasher rinse. I don't use dishwasher soap.
tonyp
Full Member
Reply #5 on:
October 30, 2006, 04:13:09 pm »
What do you soak them in?
The important thing to remember about dishwasher detergent is that it doesn't foam.
Brookenstein
Senior Member
Reply #6 on:
October 30, 2006, 04:23:31 pm »
I soak em in the bright red/purple filter cleaner crap. I use a five gallon bucket from Home Depot, hence I can only do one at a time. After I spray the crap out of it, I run it through the dishwasher, then I spray it off with the hose again... overkill yes, but I never have any foam either.
Last Edit: October 30, 2006, 04:25:21 pm by Brookenstein
Spiderman
Full Member
Reply #7 on:
October 30, 2006, 10:41:09 pm »
I didn't think you needed to soak the Tri-X filters in cleaning solution; just hose 'em down, or run 'em through the dishwasher with no detergent?
People suffer one of two pains in life: the pain of discipline, or the pain of regret
Brookenstein
Senior Member
Reply #8 on:
October 30, 2006, 10:46:19 pm »
I don't do it very often, especially lately, but I do do it. Next month I will have had my tub one year. I've done the overnight solution once. I have done the spray stuff probably 3 or 4 times.... probably whenever I did water changes. My understanding is that the filters can still get clogged microscopically and that hosing it off won't get it and that they need the occasional actual 'cleaning'. But I've been known to be wrong.
Tubaholic
Junior Member
HS Grandee Indoors
Reply #9 on:
October 30, 2006, 11:40:39 pm »
I also have the tri-X filters and in the last 2 years have cleaned them 2 times with the chemical cleaner soaking them in my utility sink overnight then hosing them off and into the dishwasher they go. Mostly I have rinsed with the garden hose and then into the dishwasher and that does a fine job. But my dealer has told me they can clog up so I do a chemical clean on ocassion. I also use a scum ball in the tub so there is never any oils in the tub and have found the filters and the tub stay much better in the long run...
kervis
Full Member
runnergirl
Reply #10 on:
October 31, 2006, 07:46:22 am »
Mine came out just fine.
I soaked each filter for at least 8 hours--some longer. Then I hosed them off pretty well and was getting VERY nervous when foamy bubbles kept coming out, even though I was finished....tonyp had mentioned that.
I put them into the dishwasher for a full cycle with NO cascade and I have had no foaming in the tub, thank goodness!
I think I will continue to clean them more often than I have been, with Cascade in the dishwasher, and perhaps just soak them overnight once a year, in the filter cleaner.
Brookenstein mentioned the filters clogging microscopically--The directions on the bottle say that the deep cleaner will remove dirt. grease, oil buildup and scale.
The Cascade should be able to handle everything but any scale.
Now I have to decide if I really want to store a bucket of chems for another year.
2005 HS Vanguard
Reply #10 on:
Pages: [
Original
