Author Topic: Its about time??  (Jacuzzi question)  (Read 2254 times)
slimchance
  • Jacuzzi J-365 Oh Ya!!
« on: October 15, 2006, 10:12:31 am »
Well the tub has been up and running for a few days now and everything is running flawless, well almost everything…
My j-365 is losing about an hour a day??  Not sure if this is a problem since I don’t rely on my hot tub for giving me the time of day.  I know it just uses a 24 hour clock for doing its filtration cycles.  Is this common, or should I be worried?
tileman
Re: Its about time??  (Jacuzzi question)
« Reply #1 on: October 15, 2006, 10:15:24 am »
What do you mean it's losing an hour a day?
slimchance
« Reply #2 on: October 15, 2006, 07:23:00 pm »
I set the timer on the contol panel (Hour, Min, am/pm).  It has 4 automated filtration cycles above and beyond the 24hr circ pump.  Sort of a deep filter cycle.  I can adjust set points for when it does this and for how long.  I noticed after a couple of days that when it goes through one of its cycles, it is not where I set it according to real time.  When I check the panels time display, its way off.
OOPS... I looks like I'm gainig an hour every day not loosing. ::)
ndabunka
« Reply #3 on: October 15, 2006, 09:20:52 pm »
Do you mena gaining an hour every day AND each day?  Or is it just off by a hour?
slimchance
« Reply #4 on: October 18, 2006, 06:48:12 pm »
On Friday I set the tub time to my watch.  By Sunday it was 2.5 hours ahead of my watch.  I have put in a call to the dealer.  They called and said they are contacting Jacuzzi.  Not sure where it goes from there but other then that the tub is amazing!!!
« Reply #5 on: October 18, 2006, 09:42:13 pm »
Could be using dog years. Or Canadian time, EH?
 8-)
In Canada eh
« Reply #6 on: October 18, 2006, 10:27:00 pm »
 8-)
 ;D ;D ;D ;D ;D
But if it were Canadian time wouldn't you lose 15% everyday ;)
Bullfrog 451
