I'm curious what was the determining factor for you choosing Arctic vs. other brands?Was it the Heatlock design? If so why? Because of the potential cost savings in electricity?
Quote If there is one consensus in this industry it's this. HOT TUBS WILL LEAK SOONER OR LATER! There is no such consensus unless you're talking about "forever". A good spa should last you 10+ yrs and it is not uncommon to see 15, 18 or even 20 yr old spas out there is they are well made. You do not need to expect that all of those would have leaked at some point. My spa is 8 yrs old and has never leaked and I have no expectation that it will leak in the next 10 yrs but there is certainly a chance. Now if you were to ask me if it will leak in the next 80 yrs I might be less confident but there is somewhat of a finite life expectancy of your spa. If it is built well you do not need to sit there expecting that it will leak within the spa's life expectancy. Certainly there is a certain % will leak but it should be VERY very low rather than some "sooner or later" expectation as you've been led to believe. Again, I'm talking about quality built spas.
Congrats on your purchase. The waiting is the hardest part. I love my Summit Legend SE, and the Tundra seems to be a great seller.When you sit in it for the fisr time in your own back yard, don't worry- you wont be thinking about TP vs FF vs Heatlock......
My opinion is you shouldn't have used insulation and/or quality as a deciding factor in your spa purchase.Now if you would have said something like..I liked the look, color, and feel of the arctic and, to boot I got an exceptional price that nobody else could beat when comparing the features that I thought were important to me..That would be a different story..Either way, enjoy the rest of the process, and your hot tub..
If thermal lock insulation or whatever people call their dead air space insulation is so good, why don't they use it in their covers. Lets make a a cover with an open area in between some foam and heat it with a pump 8 hours a day. Just curious. As for a Beachcomber losing heat, while sitting in a 750 this weekend, we ran the jets for 40 minutes straight and the temp went up from 104 to 105 so much for heat escaping from a full foam tub with the equipment "on the outside"I've said it before and I'll say it again. Choose comfort first
Next, most arguments between the FF and the non-FF folks center around cost efficiency and repair costs. I have never seen any evidence by the FF people suggesting that their system is less expensive to operate but I have seen a study (admittedly commissioned by Arctic) that shows the Heatlock system to be on average less expensive to operate than comparable FF models. (Their study seems to be objectively administered as one Arctic model was not in the top echelon of efficiency, and no other mfgs have to my knowledge objected to the study).
QuoteIf thermal lock insulation or whatever people call their dead air space insulation is so good, why don't they use it in their covers. Lets make a a cover with an open area in between some foam and heat it with a pump 8 hours a day. Just curious. As for a Beachcomber losing heat, while sitting in a 750 this weekend, we ran the jets for 40 minutes straight and the temp went up from 104 to 105 so much for heat escaping from a full foam tub with the equipment "on the outside"I've said it before and I'll say it again. Choose comfort firstYour first comment doesn't even dignify a response. The more I'm on these websites, the more I find people can't read and understand or want to listen to different opinions. And I never ever said anything about a Beachcomber. See ya all much later.
QuoteQuote If there is one consensus in this industry it's this. HOT TUBS WILL LEAK SOONER OR LATER! There is no such consensus unless you're talking about "forever". A good spa should last you 10+ yrs and it is not uncommon to see 15, 18 or even 20 yr old spas out there is they are well made. You do not need to expect that all of those would have leaked at some point. My spa is 8 yrs old and has never leaked and I have no expectation that it will leak in the next 10 yrs but there is certainly a chance. Now if you were to ask me if it will leak in the next 80 yrs I might be less confident but there is somewhat of a finite life expectancy of your spa. If it is built well you do not need to sit there expecting that it will leak within the spa's life expectancy. Certainly there is a certain % will leak but it should be VERY very low rather than some "sooner or later" expectation as you've been led to believe. Again, I'm talking about quality built spas.That' why I stated "sooner or later". Yes, a quality built spa could go a lifetime without leaks, but all I'm saying is that leaks are possible with any, including Arctic. If a leak does develop, the argument is over as to which unit will be easier to repair. Common sense tells all of us that finding and repairing a leak in a FF tub will be definitely more difficult and time consuming to repair. But I did not buy the Arctic ONLY because of the Heatlock system, but rather for a variety of other quality issues, # of jets, comfort, seating arrangements, etc.
You asked orginally about Beachcomber and when you go to Arctic's website, were you recieved alot of your information, they deliberately attack Beachcomber with their diagram and analogy of a heater on the outside of the house and how it doesn't make sense. Anything can be taken out of context.
These forums are full of dealers disguising themselves as consumers making their opinions sound like fact.
My comment about the cover was done tongue in cheek and the longer i'm on these websites, the more I find people with no sense of humor. You asked orginally about Beachcomber and when you go to Arctic's website, were you recieved alot of your information, they deliberately attack Beachcomber with their diagram and analogy of a heater on the outside of the house and how it doesn't make sense. Anything can be taken out of context. Comfort is the most important thing when buying your tub, ask any professional that cares about the industry. Ask any professional that cares only about there product and that is where the debate starts. These forums are full of dealers disguising themselves as consumers making their opinions sound like fact. The only real fact is, those you feel more comfortable in their tubs use them more and they don't give a flip about electricity costs. If you are buying because of jet count, well that's another issue, but if you wet tested and liked it, who cares what anyone else thinks, and which point, why post?Unless you have an agenda. To all my fellow professionals that care about the industry and growing it, I salute you. For those here just to promote their agenda and disguise it as if they are a consumer, well I salute you also, for giving this industry a black eye.
