Author Topic: Stabilizer?  (Read 3550 times)
Venissa
  • Proud owner of a Coleman model 461
Stabilizer?
« on: October 06, 2006, 10:27:10 am »
I just did a fresh refill and am still trying to figure out how to adjust the chemicals.  Everythng is reading perfect except Stabilizer and it reads very low according to the test strips.
I always thought Stabilizer was shocking the spa.....Am I wrong?  Do I need a purchase a chemcial to bring the Stabilizer reading to were it should be?
Don't throw away the old bucket until you know whether the new one holds water.
Stabilizer?
The_real_Clown_Shoes
Re: Stabilizer?
« Reply #1 on: October 06, 2006, 12:31:30 pm »
Stabilizer is Cyanuric Acid, or CYA for short.  It is pretty much negligible in a spa, as all it does is keep the chlorine from being eliminated by the sun.  Since your spa is covered most of the time, you don't even WANT a high amount.
Your CYA will build up over time as you add dichlor or brominating concentrate.
Venissa
Re: Stabilizer?
« Reply #2 on: October 06, 2006, 02:53:56 pm »
Thats nice to know......These test strips confuse the heck out of me.....I never know which test matters and which dont - These strips have 6 readings and I was trying to keep them all perfect.  I need strips that show me ONLY what I need to worry about!!!  If there is any such strip.
Thanks - I was beginning to wonder if anyone was going to reply.
Repeat_Offender
Re: Stabilizer?
« Reply #3 on: October 06, 2006, 02:57:41 pm »
The test strrips I use have four indicators
Bromine Level
PH
Total Alkalinity
Hardness
That should pretty much cover it.
Bullfrog 562
Venissa
Re: Stabilizer?
« Reply #4 on: October 06, 2006, 03:01:34 pm »
I'm going to buy new strips!!  These are killing my nerves!  :o
Bromine Level
PH
Total Alkalinity
Hardness
Re: Stabilizer?
