Author Topic: Dichlor  (Read 1601 times)
The_Pa._Lady
Dichlor
« on: September 27, 2006, 10:48:38 pm »
Would someone please tell me, do you add the Dichlor before or after using the hot tub?  I just know I need to add the stuff.
Dichlor
badval
Re: Dichlor
« Reply #1 on: September 27, 2006, 10:55:36 pm »
That's really up to you, but I like to do it after.  I figure doing it after kills off whatever we left behind & then leaves nice clean water for next use.  If I don't get in it that night, the next morning I add a small amount so it doesn't go 48 hrs w/o having at least a little added.
In Canada eh
Re: Dichlor
« Reply #2 on: September 27, 2006, 10:58:15 pm »
For an average size tub
1 teaspoon per person after you use the tub
If you want to get real fancy, you can fine tune the measurement by taking a chlorine residual reading 20 minutes after using your tub and it should read about 3 ppm
Bullfrog 451
Re: Dichlor
« Reply #3 on: September 28, 2006, 08:09:18 am »
I also dose after use.  That way the bad guys get nuked, and the chlorine level is very low for the next use.  If we go a couple days without using the spa, I add some in between.
For me, 2 tsps. brings up the chlorine to the suggested level.
I'll add more for a higher bather load, usually it's just the 2 of us.
 I use a couple TBSP's to shock.
« Last Edit: September 28, 2006, 08:11:35 am by Brewman »
hottub.pool_boy
Re: Dichlor
« Reply #4 on: September 28, 2006, 08:15:35 am »
 As long as prior to your use, the water's nice and clear with small residual 0.5-3ppm of free chlorine. Add dichlor when you're done with your soak.
Re: Dichlor
