Author Topic: What tubs show the ACTUAL temp on the console?  (Read 4201 times)
gores95
  • '06 Caldera Geneva
« on: September 22, 2006, 07:44:21 pm »
We just bought a Caldera Geneva and it will be delivered in a few weeks.  I am not even sure if the actual temperature is displayed or if it is just the set temp.  Does anyone know what spas show BOTH?  I just assumed this would be the case on my Caldera....was I wrong?  And if not is this a big deal???
Thanks.
badval
Re: What tubs show the ACTUAL temp on the console?
« Reply #1 on: September 22, 2006, 08:11:15 pm »
Mine (Leisure Bay) briefly changes to the "set" temp when you push the temp ^ / v buttons, but otherwise always displays the water temp.
« Reply #2 on: September 22, 2006, 08:12:27 pm »
My Dynasty shows both. It was on option I deemed neccesary when I was buying a spa.  My friends have a low end spa with no display at all and they have to open a panel to change the temp.
Repeat_Offender
« Reply #3 on: September 22, 2006, 08:41:13 pm »
Mine does too, the default display is the current water temp.
Bullfrog 562
autoplay
« Reply #4 on: September 22, 2006, 09:23:53 pm »
My 2003 Caldera Geneva Utopia displays both.
gores95
« Reply #5 on: September 22, 2006, 09:44:01 pm »
That makes me feel better since I just bought the '06 Geneva.  Can you toggle back and forth or does it stay on one or the other?  I would think I would like the display to show the ACTUAL temp.
« Last Edit: September 22, 2006, 09:55:06 pm by gores95 »
anne
« Reply #6 on: September 22, 2006, 09:49:34 pm »
My Arctic does just as Badval's: shows actual temp unless you hit the up/down arrows to change the set temp.
Dance like nobody's watching
« Reply #7 on: September 22, 2006, 09:57:38 pm »
Artesian does ... at least a 2005 does. Hit up or down arrow and the display turns to set temp.
gores95
« Reply #8 on: September 22, 2006, 10:11:42 pm »
Thanks for all the replies.  I just went to the Caldera website and found the manual online.  My tub displays the actual water temp most of the time except when lowering or raising the temp which will briefly display the set temp.
glastron
  • no one doesnt like spatopia
« Reply #9 on: September 22, 2006, 11:38:53 pm »
digital display on my marquis
Rayman
« Reply #10 on: September 23, 2006, 07:57:29 am »
ditto for Beachcomber, both will show
« Reply #11 on: September 23, 2006, 02:47:50 pm »
Sundance 880 series checking in.  Display shows actual temp, can hit a button to see set temperature.
In Canada eh
« Reply #12 on: September 24, 2006, 08:33:33 am »
Our Bullfrog control pad operates the same way and I imagine this is a trait for all Balboa controllers
Bullfrog 451
Gomboman
  • My Pride and Joy
« Reply #13 on: September 24, 2006, 09:48:48 pm »
Hotspring doesn't display Actual Temperature for some reason. Their system utilizes a Ready Light that illuminates when your Set Temperatue and Actual Temperature are within 2 degrees or so. This seems to work for most people.
« Last Edit: September 24, 2006, 11:15:23 pm by Gomboman »
svspa
  • Jacuzzi J-345
« Reply #14 on: September 25, 2006, 11:10:57 am »
jacuzzi normally shows current temp, push a button to show set temp. BTW the current temp is always 1 degree low on my j-345 compared to my sharky thermometer :)
