Author Topic: Removing panels - frequency  (Read 2892 times)
badval
« on: September 22, 2006, 08:35:20 pm »
How often do you need to remove the panels for any reason?
I took mine off (2 sides) for the electrician (& to check all the guts out & watch for leaks) & put them back on.  Lining up exactly w/ the original screw holes didn't seem possible, so I just screwed back into the frame creating a new set of holes.
Obviously this can only be done so many times before the wood in the frame gets chewed up.  I can't see any reason for me to need to take them off again, but I'm sure it will be necessary at some point.  So if nothing is broken, is there any reason to remove any panels for routine maintenance?
glastron
  • no one doesnt like spatopia
Re: Removing panels - frequency
« Reply #1 on: September 22, 2006, 11:43:01 pm »
that might be where ur drain bib is I use a electric underwater pump so i never have to open it.except jus to check things out once in awhile.
« Reply #2 on: September 23, 2006, 02:48:48 pm »
The only panel I ever remove is the one over the service bay.  I need to remove it to access the drain.
