Original
hating water care right now....
Pages: [
Topic: hating water care right now.... (Read 2556 times)
anne
Senior Member
on:
September 15, 2006, 12:41:12 pm »
I'm hoping that someon can find a big error in my approach to water chemistry, because I can not make any sense of the pH, TA problems that I have been having. The following progression has been over the last week, since I returned from a 2 week vacation. I use a Taylor test kit, I think I perform all the tests very accurately (minding drop technique, following all instructions, etc). I use chlorine, MPS to shock, have ozone, and about a 400 gal tub.
Sunday:
FOUND: cloudy water (I've been gone- housesitter was caring for things but unlikely any sanitizer in a few days) I did not measure TA, pH (yeah, guess I should have)
ADDED: 3.5 TBSP chlorine (a little over 9X normal dose), and a bit later 2 oz MPS
Monday: (water clearer)
FOUND: FC=1, TC=5. pH 8, and I cannot remember TA. Thought TC level was odd, but considered that I might have added the chlorine and MPS to close together the day before.
ADDED: 2 more oz MPS.
Few hrs later:
FOUND: FC=5, TC=0 checked pH again to see if MPS affected: still 8.0, TA 125.
ADDED: 1.5 oz dry acid
Tuesday: (water crystal clear)
FOUND: pH 7.7, TA 80
ADDED: 6 TBSP to get TA back up before I add more acid
Wednesday:
FOUND: pH 8, TA 130
ADDED: 2 oz dry acid
Thursday: no time to measure anything
Friday:
FOUND pH still 8.0, TA 60!
I'm at a loss. Every time I add dry acid, I have a huge decrease in my TA, and little affect on pH. I know I should be taking chlorine level into consideration, but if anything, wouldn't a high chl level make my pH look falsely LOW??? With all the chlorine, mps and acid I have added, what gives?
Last Edit: September 15, 2006, 12:42:03 pm by anne
Dance like nobody's watching
on:
Stemay
Junior Member
I love YaBB 1G - SP1!
Re: hating water care right now....
Reply #1 on:
September 15, 2006, 02:51:51 pm »
It all sounds complicated for me! How about doing a water dump and starting from scratch? Sounds like things went haywire while you were on vacation.
The_real_Clown_Shoes
Full Member
Hot Spring Salesman since '05.
Reply #2 on:
September 15, 2006, 03:35:51 pm »
Anne, if you can get your pH in range, your alkalinity will be perfectly fine perching at 80 ppm. Don't worry about getting it exactly in between 125 - 150, that's just a rule of thumb to prevent your alkalinity from dipping too low.
I didn't read too in-depth on what your pH was after you added the TA increaser, but when you add alkalinity your pH typically doesn't rise too much.
What's your source water like? Would adding fresh water bring up or bring down the TA and pH?
Ultimate Member
Reply #3 on:
September 15, 2006, 07:12:33 pm »
anne,
First thng is don't take combined chlorine readings for a few days after shocking with MPS. It skews the numbers.
Second, I believe that TA will go down before PH. I've also read that if you mix the water (jets on) PH changes before TA and if you leave the water still TA changes before PH ... but I don't know if this is true.
I've also said this before - worry about PH, not so much on alkalinity. From what I've read, alkalinity only helps keep the PH stable - it seems to be doing the job here!
anne
Senior Member
Reply #4 on:
September 15, 2006, 08:04:44 pm »
Stemay-
I considered doing just that, but I only changed the water about a month ago, and I ALWAYS seem to be fighting high pH, this is just a bit more extreme that normal.
Vinny-
that is a good thing to know about MPS skewing TC readings, cuz today (after posting) I checked my FC and TC and was about to pull my hair out seeing that my TC was still supposedly 1. I'll leave that alone. Water certainly smells nice.
Giraffe- my water source has a kind a high pH, so I dont know that partial drainage and refill would help that much.
I got irritated and added 3 oz acid this morning, (pH was 8, TA was 60, so I knew I'd bottom out my TA, but every time I adjust TA first, my pH skyrockets.)
Now I'm at a pH of about 7.1 and TA of like 20. I've never seen it so low. Off to add baking soda.......
As a related but slightly separate question, does anyone out there rely on the Taylor kit "acid demand" and "base demand" tests to decide how much to add?
hottub.pool_boy
Full Member
New England's oldest HotSpring Dealer- 1983
Reply #5 on:
September 15, 2006, 11:24:45 pm »
Don't try balancing(Alk.,ph,ch) your spa with a high chlorine reading. Wait for the chlorine to fall, then balance.
For the future, if the tubs out of whack, balance FIRST, then shock.
anne
Senior Member
Reply #6 on:
September 16, 2006, 01:07:03 am »
I'll keep that in mind.
oops. I was impatient to get my water clear ASAP after not having a hot tub for over 2 weeks!
Reply #6 on:
Pages: [
Original
