Author Topic: Newbie's 2nd question - Circ Pumps  (Read 3211 times)
Silent Water
  • 2006 Sundance Bahia
« on: September 15, 2006, 01:40:56 pm »
There seem to be 2 distinct schools of thought about separate circ pumps.
What's the general consensus out there? Are 24/7 circulation pumps:
a) More economical to run than cycling the jet pumps for 6 hours /day?
b) Quieter than bigger pumps?
c) More likely to wear out sooner because they are smaller and running 24/7?
I like the idea of having a dedicated pump for circulation but I don't know anything about their longevity.  I've also heard stuff about stagnant water/sediment in the jet lines with the smaller circulation pumps.  It also makes sense to me that adding another pump would add to the cost of the tub but I haven't really noticed that in the market. Any easy answer out there?
...because integrity's the key
SerjicalStrike
  • Reinstate Hank Williams!!
    • Great Bay Spa and Sauna
Re: Newbie's 2nd question - Circ Pumps
« Reply #1 on: September 15, 2006, 01:59:07 pm »
There are 3 shools of thought:
1--No circ pump
2--Small circ pump
3--Large circ pump
They all have their advantages and disadvantages.  There will be no easy answer to which one is best.
« Reply #2 on: September 15, 2006, 06:02:26 pm »
I'd wouldn't have that issue very high up on my list of spa selection criteria.
It's all just a slightly different way to filter the water.  If your water is clean, then your filtering system is effective.
Some food for thought:
My Optima uses the small 24/7 circ. pump coupled with a 2 speed main pump, pulls water thru a different filter, and runs 4 times per day, up to 24/7.
So far I can say:
My circ. pump is almost silent.  But the main pump on slow speed is very quiet too, just not quite so much as the circ. pump.  But I use both for filtering, not just one.
I've already had one circ pump replaced under warranty, at about the 30 month mark.
Not sure if my small pump running 24/7 will wear out faster than a larger pump being switched on and off four times per day.
So far the large pump is winning that war.  It's not needed service yet.
Amanda_Panda
  • Clearwater
« Reply #3 on: September 15, 2006, 06:19:14 pm »
Larger circ pump should be roughly the same cost as reg. pump on low speed for that amount of time (give or taike just a little bit)
Definately quieter
Smaller circ pump (9-10 gallons) would be working a lot harder than a larger circ. pump (30+gallons)
There's a lot of different opinions about circ pumps so there really isn't an "easy" answer. Take in all the info. and try to avoid all the "sales" jargon and hype.
« Last Edit: September 15, 2006, 08:52:01 pm by Amanda_Panda »
The best intention pales in comparison to the smallest good deed.
Gary
« Reply #4 on: September 15, 2006, 07:01:15 pm »
A. That is a myth
B. Depends on the brand
C. Most pumps big or small will last a long time. 95% of the pumps I change are because of the consumer neglect.
Personally I do not like the small circ pumps, the more water you can filter the better off you are. Circ pumps do have their place though, it is called garden pond.
« Last Edit: September 15, 2006, 07:27:15 pm by Gary »
« Reply #5 on: September 15, 2006, 07:23:49 pm »
Circ pump or not is not that big of a deal.
I have a large circ pump and it does hum - the quietest pumps are the ones that aren't on! But having a large therapy pump may disturb you and your neighbors if it's running for 3 or so hours at night if your trying to sleep. My pool has a 1 HP pump and you can hear it when it kicks on at 4 AM. It's far enogh away from the house that it's not too bad.
Circ pumps may be the way to go IF you want to run ozone 24/7. This is dependent if you believe ozone works the way it is sold by some dealers.
