Sounds like everything's not perfect with 2-speed pumps though. Added cost and decreased reliablity would be a major bummer.
Now there is an idea that I think I would like! Variable speed would be a nice option as long as the pumps are reliable.
My tub has 2-2speed pumps and a circ pump. We use the low speed more than 90% of the time. I wouldn't own a tub without the 2 speeds.Rayman
Would there be any extra wear on the motors/plumbing if most/all jets were adjusted down/off?
QuoteWould there be any extra wear on the motors/plumbing if most/all jets were adjusted down/off?Windsurfdog, No, you can completely deadhead a centrifigal pump for short periods with no damage to the impellor. Long term deadheading could damage the mechanical seal
Certainly I would think that systems where qualitly control (especially at glued fittings) is dubious that the extra pressure may have its effects.
QuoteNow there is an idea that I think I would like! Variable speed would be a nice option as long as the pumps are reliable.Tanstaafl easy to do once tub is out of warrantyLets see 2 variable frequency drives(weatherproof of course) 2 DC motors for above 1 weatherproof control panels $10,000When would you like me to start
You don't need 2-speed pumps for the jet pressure adjustments as you use diverters for that. My Jacuzzi has one 2-speed and one single speed. There is little or no theraputic value in the 2-speed at the lowest speed (no matter the diverter settings).
