Author Topic: Marquis dealers, a question for you  (Read 2372 times)
Bonibelle
  • '05 Marquis Epic
« on: September 14, 2006, 11:38:50 am »
I have been happily and successfully running my Epic in economy mode since early spring. I have my filtration cycles set for 1 hour in the morning and 1 hour in the evening right before we soak. My smart clean is also 1 hour.  My question is ...Why can't I stay in economy mode if I modify my cycles when a one hour filter cycle isn't sufficient to keep the tub temperature at 101?  Alternately, standard mode checks the temperature every hour( I believe it is every hour) by running pump 1 and will allow pump 1 to run and heat when necessary.
Is there a big advantage to standard mode?
I guess I am having flashbacks to my well problem and the plumber telling me a pump can run forever once it is on, it is the on and off cycling that causes it to wear out faster. Is that right?   :-/
Mendocino101
Re: Marquis dealers, a question for you
« Reply #1 on: September 14, 2006, 12:45:44 pm »
Bonni, you should be filtering for 2 hours twice a day, try it and I think you will be fine.
Bonibelle
  • '05 Marquis Epic
« Reply #2 on: September 14, 2006, 01:08:24 pm »
Mendo, Do you mean if I up my times to 2 cycles of 2 hours each, I can stay in Economy mode all winter? that sound good and efficient to me. Thanks
« Reply #3 on: September 14, 2006, 01:15:34 pm »
Hey Bonnie, hows the electric bills lately?
Mendocino101
« Reply #4 on: September 14, 2006, 01:46:12 pm »
Yes it is reasonable, you may have to do some tweaking but it is do able....
Bonibelle
  • '05 Marquis Epic
« Reply #5 on: September 14, 2006, 02:02:19 pm »
Thanks, Mendo, I'll let you know how it works out as it gets colder here.
 Drew, My first electric bill, without my constantly running pump..$181.00! Which was great because I was running my tub, my pool and air conditioning (all three zones). So that was a relief...my prior bill (and I was only using a whole house fan because I was afraid to turn on the air) was >$300.00! It really made a difference and I am so relieved! :)
