Author Topic: HS Soothing Stream - did you put anything in it?  (Read 3615 times)
aaronr
« on: August 30, 2006, 12:08:36 am »
I just got a Vangaurd and have 2 quick questions.
1. For those of you with Hs tubs that have a soothing Stream water feature- did you put rocks (or anything else) in there?
2. Mine has nothing in it, but it's powerful enough that water goes out the side- will putting something in there help?
Vanguard
Re: HS Soothing Stream - did you put anything in i
« Reply #1 on: August 30, 2006, 12:38:09 am »
Putting rocks in it will give it a different sound.  You will need to put decent size rocks in or else they may end up in the spa.  You may find that water will still run over the side into the spa, but that is really no big deal.
If you don't want it running that hard, you can turn it down with the valve.
I put some clear glass "rocks" in mine.  It looks neat because the light reflects off the rocks.
« Last Edit: August 30, 2006, 07:44:23 pm by aquatub »
kervis
  • runnergirl
« Reply #2 on: August 30, 2006, 09:19:57 am »
The water runs over the side with mine also--glad to hear it's not just me!  We tried one laser engraved, smooth rock, but that didn't cut it.  It looked dumb, so it was removed.  I like Aquatub's suggestion  of using a bunch of clear glass rocks that help reflect the light.  I think they have some nice big ones at Michael's craft store and I will try them out-thanks!
My next issue is one of those tiny jets above the moto-massage.  It shoots water up into my ear, hair, and all over the inside control panel to my left.  It won't stay put.  I did have a tech out to look at it and he seemed to think it was some type of possible flaw in the shell--the opening is too big or something, and it allows the jet to move freely and squirt all over the place.  He changed it out, and the new jet did the same thing, thus his conclusion above.  He offered to silicone it for me and I guess I'll have to take him up on it before winter comes!  Maybe I should try one of those spinner jets there?
We are really enjoying our Vanguard!  :)
2005 HS Vanguard
cooltoy2000
  • Go Flames Go!!!
« Reply #3 on: August 30, 2006, 03:30:16 pm »
The sound is better with something in there and the rocks look good too.
I initaly put glass rocks into mine, I loved the way the light reflected through the rocks, however one time we had friends over and it was late in the evening on a fairly chilly night and we noticed that the glass cracked into sharp slivers. Not sure if it was due to the fact that the glass was cheap or the fact that they were cool and cracked when the hot water hit them.
We switched over to polished river rock. .
East_TX_Spa
    • I Love My Spa
« Reply #4 on: August 30, 2006, 04:24:21 pm »
Terminator
The_real_Clown_Shoes
« Reply #5 on: August 30, 2006, 07:35:56 pm »
You can turn down the flow to the Soothing Stream and then it won't spill over the side.
kervis
  • runnergirl
« Reply #6 on: August 30, 2006, 08:21:50 pm »
Terminator
Out of nowhere, this has just totally cracked me up.  I'm laughing so hard, I'm crying....must go find a tissue! ;D ;D ;D
I did purcase some odd-shaped glass rocks today and put them in.  We'll see what it looks like tonight.  Interesting about them shattering in the cold.   Still LMHO!!!!
2005 HS Vanguard
hot tub Frank
  • tiger river bengal
« Reply #7 on: August 30, 2006, 08:34:40 pm »
Hi Badval
I have an old leisure bay tub. I have to say that mine runns still very good.
it is true that is is impossible to reasearch on leisure bay products. i tried that and failed big time. for the money you are spending look for other products. the changing light is not worth 250$. for 39$ you can by a bulb witch does the same thing. that is what i did.
but once again. my tub is 7 years old and i love it.
good luck and dont expect any service out of the rec warehouse. i bin down that road also.
cooltoy2000
  • Go Flames Go!!!
« Reply #8 on: August 30, 2006, 09:25:35 pm »
Ehhh?
Vanguard
« Reply #9 on: August 30, 2006, 09:40:28 pm »
Hi Badval
Methinks you are responding to a different post - one about Leisure Bay??
East_TX_Spa
    • I Love My Spa
« Reply #10 on: August 31, 2006, 12:12:43 pm »
I put some polished rocks in there.  It looks pretty good in person, but looks like cat squat in the picture.
Terminator
Jack_L
« Reply #11 on: August 31, 2006, 07:36:16 pm »
I had heard that if you leave the waterfall on it will divert water from the circ filter, is that true?  Personally for me the waterfall is annoying and I just leave it off, but my wife likes to have it run from time to time for that 'asmospheric sound', or maybe its just because its there.
TimC
« Reply #12 on: August 31, 2006, 08:36:48 pm »
Anyone thought about creating an insert to produce a Fountain?  Tried to make a prototype from wood that worked OK, but soon the wood swelled and it wouldn't fit anymore.
It seems like you could create a plastic insert to get a single or double stream to spray out.
« Last Edit: August 31, 2006, 08:37:14 pm by TimC »
Vanguard
« Reply #13 on: August 31, 2006, 09:36:51 pm »
Its not diverted from the filter.  It is diverted after the circ pump.
MarKee
« Reply #14 on: September 01, 2006, 03:34:51 am »
for some reason plastic and rocks dont mix for me
