Author Topic: ph minus allergy  (Read 1807 times)
wilfried
ph minus allergy
« on: August 31, 2006, 04:19:08 pm »
Hello
The ph value of the water was 8,5.
I used ph-minus product to reduce the ph-value to 7,4.
When i use my spa now, i have an irritation in my throat.
Has anyone had a problem like this ? What did you do ?
Can somebody me help pls.
ph minus allergy
Bill_Stevenson
  • Hot Spring Envoy
Re: ph minus allergy
« Reply #1 on: August 31, 2006, 04:24:31 pm »
We need more data.  What is total alkalinity, total dissolved solids, what are you using for a sanitizer?  If it is dichlor what is the total chlorine level?
Regards,
Bill
« Reply #2 on: August 31, 2006, 04:53:16 pm »
Yes, knowing all the chemicals you use in the spa would be helpful.  The Ph decreaser may be the culprit, or maybe some other chemical you might be using.
Baqua Spa made us cough, but on fresh water it took a couple of weeks for the water to get to that fizzy stage.
