Author Topic: Importance of a routine  (Read 2177 times)
kervis
  • runnergirl
« on: August 30, 2006, 09:34:40 am »
Just read GaryJr's post about adding chems to the tub and the reaction of the water that followed.  Vinny mentioned not adding enzymes when the chlorine is high...
I myself have managed so far on what seems to be dumb luck, but I am seeing the great importance of a routine. I do not have one yet. I'd also like to not be "wasting" chems by adding them at the wrong time where they then may become ineffective.
Is there a list of rules that describes what to add, how much time to let pass before adding the next chemical, what chems should not be mixed on the same day?  :-/
Would some of you share your routines please?  Thanks!
2005 HS Vanguard
Movinon
  • Grilln and chilln
Re: Importance of a routine
« Reply #1 on: August 30, 2006, 10:04:01 am »
Yes, please, as a new Vanguard owner I would love to get the same kind of information.
« Reply #2 on: August 30, 2006, 10:33:44 am »
My routine is pretty simple and quite effective.
 After each soak I add 2 tsp. of dichlor, and run pumps to circulate.
If we go more than a few days in a row without using the spa, I add a couple tsp. of dichlor anyway.
 Every couple week or two so depending on use, I shock with about 2 tablespoons of dichlor.
Every month or six weeks I shock with MPS- not sure why, other than I have a container full of the stuff left over from my bromine days.
Weekly, I test the water for Ph and alk, and adjust if necessary.  Usually not necessary.  I also add a metal and scale control product every week- not sure if it's necessary, but I still use it.
I spot test for chlorine, usually after I shock, just to be sure the level is down enough if we want to soak.  When I switched to dichlor, I tested for chlorine a lot, to get familiar with how much to use and when, etc...
Change water every 3 or 4 months, clean filters as needed, intensive cleaning between water changes.
Not much more to it than that.
Movinon
  • Grilln and chilln
« Reply #3 on: August 30, 2006, 10:40:56 am »
Excellent, thank you.
windsurfdog
« Reply #4 on: August 30, 2006, 03:20:02 pm »
Brewman's routine is right on the money, IMO, except for the metal and scale control.  I use the "rule of least chemicals" which encourages using the least amount of chems possible.  Unless you have really whacked out water, which is certainly possible if you are on a private well, I would leave additives like this out of my routine.  I am on a municipal water system and have never added metal and scale control--after 2 years, there are no signs that I needed it.  Remember, everything added to the water contributes to TDS...don't add it if you don't need it...or even if you are not sure if you need it or not.
« Reply #5 on: August 30, 2006, 03:46:52 pm »
I concur, wsd.  I started using the stuff because it was offered as part of Brilliance's bromine kit, and continued to use the stuff after going to dichlor.
  It's kind of a not wanting to upset the apple cart thing- with this routine my water has never been easier to maintain, and I am hesitant to change anything in the routine, including nixing the metal and scale control.
