Author Topic: Do Ozone bubbles show?  (Read 1817 times)
Garyjr
  • Let's SunDance!!
« on: August 22, 2006, 09:00:13 pm »
Have what might be a dumb question, but I am going to ask anyway.  The ozone generator in my Maxxus went out about a week after buying the tub.  The dealer came and replaced the SunDance generator with I believe a JED generator.  I could have swore with the SunDance generator, I would actually see tiny bubbles rising when the oxone LED was lit up.  Since replacing the generator, the LED appears shortly after the pumps turn off, however, I no longer see any bubbles.  Should I be concerned, or was it my imagination that I use to see them?  I am sure it is working because the LED light comes on, however, maybe it is possibly not putting out enough gas?
Should I contact my dealer and get them back out here?
Thanks again,
Jr
hottub.pool_boy
Re: Do Ozone bubbles show?
« Reply #1 on: August 22, 2006, 09:11:33 pm »
If the injector was changed as well it could be a finer/ mist type of bubbles. Never the less, should be a fine mist of bubbles. They may know something I don't. Couldn't hurt to give them a call and ask what you should see. Good luck.
Garyjr
  • Let's SunDance!!
« Reply #2 on: August 22, 2006, 09:52:09 pm »
Thanks hottub.pool_boy I was certain that there was a steady stream of bubbles before they replaced the unit.  The unit they replaced the defective one with is about 1/4 the size of the actual SunDance oxone box.  The service guy said they always swap the defective generators with I believe it was a JED generator. Is it possible they put in too small of a generator for my big ole tub?
Thanks again,
Jr
Vanguard
« Reply #3 on: August 22, 2006, 11:04:35 pm »
There should  be bubbles.  After the ozone is depleted, it turns into oxygen and oxygen bubbles in water.  If you don't, you may have a check valve issue or injector issue.  Those should not be bad that quick, but could be an exception.
Pathfinder
« Reply #4 on: August 22, 2006, 11:15:14 pm »
Agreed, there should be bubbles  regardless is the ozone is working or  not   open the equipment area  see if your tubing is connected properly. If your ozonator is under warranty I wouldn t really settle for an aftermarket  ozonator  if you paid extra for the sunzone ozonator your dealer should put the right one in.  As Aquatub said you may be dealing with a clogged bose injector
Garyjr
  • Let's SunDance!!
« Reply #5 on: August 22, 2006, 11:40:26 pm »
I will call the dealer in the morning and see about getting them back out.  Do I understand correct that the SunDance ozone generator is of better quality than the one they replaced it with?  If so, I will see about having the replacement replaced with an OEM part.
Thanks again,
Gary
