Author Topic: ozone system or salt-water  (Read 3509 times)
Styx555
« on: August 14, 2006, 08:53:34 am »
Considering both options right now? My concern with the salt system is early corrosion due to the salt. Any input?
Vanguard
Re: ozone system or salt-water
« Reply #1 on: August 14, 2006, 09:34:11 am »
You'll want to go with ozone.  I sat in a spa with a salt system that was being tested.  The water became effervescent and made it uncomfortable to breathe.  There are companies working on bromine and chlorine generators, but I still have not seen one for a hot tub that works well.  These have pretty much taken over in swimming pool construction, but are not there for spas yet.
The_real_Clown_Shoes
« Reply #2 on: August 14, 2006, 10:42:35 am »
I wouldn't recommend a salt-generator for a spa.  The TDS will go way off the charts, and it's really a little too much overkill.
Styx555
« Reply #3 on: August 14, 2006, 11:15:30 am »
The spa I am looking at does not include either and will require adding it on. Would you reccomend adding the ozone system or not adding anything at this point? Is it much cheaper/better to use ozone?
« Reply #4 on: August 14, 2006, 11:25:19 am »
I'd stick with ozone but also you need to realize there are cheap uneffective ozone systems and good effective ones. What are you looing at. UV, CD, chip replacements, etc.?
