What is "biofilm" in the lines and how can I solve that problem?
QuoteWhat is "biofilm" in the lines and how can I solve that problem?Biofilm is a biological growth that forms on the inside of pipes due to low chlorine levels or in some instances low flow rates. The only way to eliminate it is to super-chlorinate. Add enough dihlor to achieve about 5ppm(test 15 minutes after adding), once you reach 5ppm leave the tub sit for about 12 hours and you should be OK. I would probably shock the tub at this point cause things could get a little stinky as the chlorine starts to break down the YUK. Don't worry, its not as bad as it sounds.
OK - about 8 hours ago I put 1.5 cups of dichlor in the tub. I know I was well above 10PPM even after checking after 15 minutes. Now I get a reading of 0 again AND all my other levels (ALK, PH, CH) are reading 0! My water still looks crystal clear. What now? Is the water still safe? I was in it last night with no problems (before I tried this process).
